Camber Compensator Suppliers
- Camshaft
- Been thanked: 107 times
Re: Camber Compensator Suppliers
Boet Bugger !! so in essence what you saying is that the tension is at the ends of the spring blade pulling the axleand wheel down,.....thereby "trying" to lift the car !!. Therefore a compression force on the g-box........that is tihe complete opposite the way I was trying to work this lot out!!!!
I had it that the ends of the blades creates a compression at the wheels therefore pushing the wheel deeper into the wheelwell,...hense the tension at the g-box!
Never too old to be learning/correct your line of thinking !!
Well,......I need to get into this process and understand this first,....
Thank you. Haans
Thank you. Haans
What are you actually looking to achieve?
By your previous post you are looking for a Rear anti roll bar set up
If you go around
Say right hand corner
The pressure forcing left wheel in is used to lift rhs wheel inwards to keep body as straight as possible
My Squat bar is more for Hard pull offs
If you go around
do some reading on what a rear anti-roll bar does to a swing axle car.
Yes you can buy them. From what I've read, I'd rather not.
The track racing guys modify and upgrade the existing Z bar
I did the same for my Bloodhound bug when we went to Hakskeen pan
Main reason aswell was to eliminate the rear wheels tucking in if I would have turned sideways losing it on the Sand
I managed a 215Km/h
On the pics you can see how the rear wing works very well with the Airflow of the Dust
I managed a 215Km/h
- V6 Capri
- Has thanked: 7 times
- Been thanked: 29 times
Is it my imagination, or does the car sit quite low at speed?
Wing works great though.
1964 Ford Anglia 997cc
1972 Ford Capri 3L GT
1996 Escort 2L Zetec
2016 VW Touran 1.6TDi
1971 Baywindow project
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
has any tried something like this?
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
- John Alves
or something like this?
1968 1500 SP Beetle
1968 1500 SP Beetle
If you want the car not to sit down like a lam dog when pulling away, you set up the spring or fit coil overs.
If you do not want the wheels to fold under the car on a sharp turn, then fit straps. or a strong bunggy cord from top shock mount around axle and back to shock mount.
If you want to have fun or are a windgat with your Aircooled, then fit both
With the extra power I have in my Fastback, my Fleetline as well as my 52 Beetle, I have fitted coil overs on all 3 at the back.
OMO
OMO
- Camshaft
Herman,....want to look windgat and more over safe from not rolling over.
Coil overs,....can you be more specific ?
Volk spares sell them and some others as well.
- What model do you have?: JEEP (Veep)
Good day Hans they usually sell them for beach buggies
R3500 for set of 2.
- Camshaft
Thanks gents. My budget is being closely scritinized by you know who, shocks will have to wait
- Been thanked: 5 times
I have been thinking about this for a bit and decided to go my own way with a CC. However, I want it to attach to the forks, as opposed to the gearbox - like the original EMPI's used to do. So here is idea at this stage (including a mid-mount):
The plan is to have the brackets laser cut from 5mm mild steel, and then welded up together as shown (Might add an extra gusset in the middle). To fit it to the forks, my plan is to drill into the forks and install steel M8 rivnuts which allow the thing to be bolted to the underside of the forks. Everything else works exactly the same as the other types of CC. Just need to find a suitable leaf spring and some straps for the swing arm tubes.
As far as I can tell, the forks are hollow, and are far enough away from the gearbox mounting frame bolts, so shouldn't present a problem for drilling.
Any thoughts from the forum?
