Page 2 of 2
Re: Engine Number
Posted: Tue Apr 14, 2020 10:36 am
by JP_Pentz
Re: Engine Number
Posted: Tue Apr 14, 2020 12:25 pm
by fig
Those are not stock carbs. Regardless of whether they were fitted with one or 2 carbs, all ACVWs left the factory with Solex carbs.
The only factory standard twin-carb engines were 1500S type 3s, 1600SP Beetles and type4-engined kombis.
Re: Engine Number
Posted: Tue Apr 14, 2020 12:59 pm
That engine could be anything inside, as over 50 years, guys have modified, swapped parts, changed and mix and matched engine parts.
So to truly know what you have is to open it and see what goodies are inside.
Just looking at that motor, would make me think its very, very far from standard.
Enjoy
Re: Engine Number
Posted: Thu Apr 23, 2020 8:25 am
by JP_Pentz
dixtoy wrote: ↑Mon Apr 13, 2020 2:05 pm
It wil be SF AS
Good day Dixtoy had i look at the NUMBER and it is n
6
it looks like
6F AS 399400
What i am trying to find is the year of the engine want to find n manual for it
Re: Engine Number
Posted: Thu Apr 23, 2020 9:10 am
That will be a badly stamped "S" not a "6"
Most VW engines are the same to repair, the only difference will be between a type 1 like yours and a type 3 or 4
You can get any manual on a 1600 beetle motor.
Your carb's are not stanard, so they will not be covered by your normal VW manual.
Re: Engine Number
Posted: Thu Apr 23, 2020 9:23 am
by JP_Pentz
retrovan wrote: ↑Thu Apr 23, 2020 9:10 am
so what is the best type 1 VW manual that you have seen Herman
Re: Engine Number
Posted: Thu Apr 23, 2020 12:01 pm
I know @fig has a few he was selling, maybe you can get one from him.
Is a good one..
Have a look here, you will find a few good ones...
https://www.amazon.com/Keep-Volkswagen- ... 1566913101
Re: Engine Number
Posted: Thu Apr 23, 2020 12:56 pm
by fig
JP_Pentz wrote: ↑Thu Apr 23, 2020 9:23 am
The best workshop manuals are the VW factory published manuals for dealers, but these are hard to find. Next is the Bentley Publishers manuals, which are somewhat condensed versions of the factory manuals. Both are expensive.
Next level is Autobooks and Haynes. These are nowhere near as detailed as factory manuals but still useful.
Then there is Intereurope and Autodata, both acceptable but quite general.
You may also come across Gregory's, later called Scientific Publications, which are published in Australia and in the same league as Autobooks and Haynes. There are also manuals published by Chilton, Glenn's and others.
You may also come across antique manuals published by Floyd Clymer, Pitman, and others who I can't recall and I'm locked down away from my library.
I don't have any Beetle manuals for sale at the moment, but I do have baywindow bus manuals from Autobooks, Haynes, Intereurope and Autodata available, for betwen R300 and R350 per manual.
If you search online, Bentley offers pdf manuals, as do a whole bunch of pirates selling illegally copied pdf manuals.
Re: Engine Number
Posted: Thu Apr 23, 2020 5:33 pm
by 73type2
The Haynes manual is available on Takealot.com. It should be good enough to help you repair your engine. Any further info you need might be found by doing online searches or asking on air-cooled forums like these.
Re: Engine Number
Posted: Wed Aug 05, 2020 9:43 am
by SLIMZ_ZA
Please help me identify the following engine in my beetle, I have looked everywhere to identify it and no luck
Re: Engine Number
Posted: Wed Aug 05, 2020 1:04 pm
SLIMZ_ZA wrote: ↑Wed Aug 05, 2020 9:43 am
Looks like an AS engine
1600
The SF means South Africa
Re: Engine Number
Posted: Wed Aug 05, 2020 1:47 pm
by SLIMZ_ZA
Tony Z wrote: ↑Wed Aug 05, 2020 1:04 pm
1600
Thank you for the speedy reply Tony
As 1600 is a dual if I remember,
