Where are you located? Maybe a helpful forum member close to you would be willing to help?
Beetle 1962
- What model do you have?: 62 beetle
Re: Beetle 1962
Purchased at ffr, sold as early model runners. Will check this evening73type2 wrote:AFAIK there are three widths, 33mm, 18mm and 10mm. '52-'64 should have the 33mm beadings. Yours look like the 18mm, but my eyesight is not the best nowadays. The 33mm beading is relatively scarce so most people make do with either the 18mm or 10mm. For me its very important detail and I was very lucky to get an original set for my '63.
The 1962 Beetle below (googled) has the correct beading:
Sent from my VKY-L09 using Tapatalk
Re: Beetle 1962
Wynberg, Cape Town. Have the beading for rear sides as well as front and rear with the the rubbers to receive already installed. Would appreciate the help
Re: Beetle 1962
If it helps, the beading is fitter into the rubber before fitting the rubber to the window, and then the assembly is installed into the car.
Re: Beetle 1962
Correct, that's where the difficulty liesretrovan wrote:If it helps, the beading is fitter into the rubber before fitting the rubber to the window, and then the assembly is installed into the car.
- Pushrod
- Has thanked: 141 times
- Been thanked: 100 times
Re: Beetle 1962
I'm also in Cape Town. Winter time in Cape Town is not the best time to install window rubbers. Better wait for a nice hot day and lay the rubber out in the sun for an hour or so prior to installation. This is a two person job but having a third pair of hands to help press the window from the outside will also help.
If you haven't come right by September I'll pop you a message to see if I could assist. No charge.
Re: Beetle 1962
Definately take you up on it. Thanks73type2 wrote:I'm also in Cape Town. Winter time in Cape Town is not the best time to install window rubbers. Better wait for a nice hot day and lay the rubber out in the sun for an hour or so prior to installation. This is a two person job but having a third pair of hands to help press the window from the outside will also help.
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Re: Beetle 1962
Looks nice and clean !
Not sure if I missed it, did you do a complete strip and rebuild or only change a few things on the car ?...before pics
Re: Beetle 1962
Complete strip but not body off pan. Will post some pics soon of the start. Still need to fit balance of windows, and king pins and.... Never ending lol
Re: Beetle 1962
I checked and see the ffr side steps have the 18mm beading. Still have my original thicker ones so will swop them over. Never really took note73type2 wrote:AFAIK there are three widths, 33mm, 18mm and 10mm. '52-'64 should have the 33mm beadings. Yours look like the 18mm, but my eyesight is not the best nowadays. The 33mm beading is relatively scarce so most people make do with either the 18mm or 10mm. For me its very important detail and I was very lucky to get an original set for my '63.
Re: Beetle 1962
Will post some before soonray1204 wrote:Slow progress but end in sight 62 bug
