Page 2 of 4
Re: My other project cars
Posted: Fri Jan 18, 2019 7:58 am
Haans wrote: Fri Jan 18, 2019 7:53 am
My humble apologies !!!!,.....I'm in a bit of a bind here. Leon ( my friend),...the owner of this fourletter word that cannot bespoken about, is in Gauteng assisting hisfamily with a medical emergency....We have to get thecar mobile!
Thanks to all for helping !
Posted: Fri Jan 18, 2019 10:51 am
by V6 Capri
I have no idea how to fix this problem. Sorry.
Posted: Fri Jan 18, 2019 11:04 am
Haans wrote: Thu Jan 17, 2019 6:26 pm
Just to add to theconfusion,......it isstill positve earth,.......from what I can gather is that the 2 white wires can be swopped over ,....dont quite know what that means
You will have to find out with a multi meter if the rev counter part of the unit is connected to the outer body.
If the outer body is metal and IS connected to the rev counter internals, then you would have to insulate the body of the meter from the car body
If there is NO connection then you can connect it any which way.
Posted: Mon Feb 11, 2019 9:34 am
by V6 Capri
Did you eventually sort this out?
Saw pictures of the George show and then this:
Almost looks like the Anglia's younger brother?
Posted: Tue Feb 12, 2019 7:43 am
by Haans
Yip,.. sort of,...after nearly burning the car to the ground !!
Changed it to negative earth,...got the dashin only to find outthat the revcounter is blown,...and the speedo cable is so worn it just does'nt fit the square in thespeedo,.....so we have a bit of work to do on this lot
Other gauges all work,..and for the trip we ran on the GPS to stay on the right side of the law
Thanks Haans
Posted: Tue Feb 12, 2019 7:57 am
by Haans
This is what the dash ended like
The blue car,..the four letter word not to bementioned on this forum is interesting,...the first time I saw it,....I thought nice, but could not pinpoint what the fus was. Leon sent me backto go and check it out again!,.....and then I realised what he has done to it!!!
What say you........Haans
Posted: Tue Feb 12, 2019 10:21 am
by V6 Capri
Was it cut to fit a V6 or V8?
Posted: Tue Feb 12, 2019 10:23 am
by V6 Capri
Haans wrote: Tue Feb 12, 2019 7:57 am
I quite like the look of this setup. A friend of mine cut his dash and recessed the gauges, which does look almost OEM nice!
Let's see if I can get his pictures on here:
Posted: Wed Feb 13, 2019 10:22 am
by Haans
That f..... vehicle was widened and lengthened and fitted with V6
Check it out again
Posted: Wed Feb 13, 2019 2:37 pm
by V6 Capri
Haans wrote: Wed Feb 13, 2019 10:22 am
Check it out again
Would love to see more pictures of this... Only ever seen a lenghend nose on a Mk1 Escort to fit a V8... but widened Anglia??
Posted: Thu Feb 14, 2019 7:36 am
by Haans
Check the rearnumber plate,......std size then the gap to the end
Was lenthened just in front of the A pillar by about ,.....a hand & half I would say
No better pics sorry
Posted: Fri Mar 25, 2022 1:29 pm
by Haans
Mr V6,. the only constant is "change" !!!!
so now Leon has sold the Anglia and got a "64 Zephyr Zodiac Mk III 6 cylinder approx 2.5 cc,..... and to cut a loooong story short !!
we have now got a 36 DCD7 carb on it BUT........to get the jetting sorted is more than a pain in the rear !!!
Ingnition is "electronic" and set,... new leads and plugs,.. so that side of the equation is sorted.
Cannot get it to rev up,... keeps on flooding which seem to indicate main jet too big started of with 130 main and 180 air with a F23 emulsion tube. It is as if you are pouring fuel down the choke !!!
currently,... 110 main and 210 air ,...idles the tank empty and dies when butterfly is opened,....indicating very little fuel,....main too small,..which makes sense me thinks
changed to 115 main with the same 210 air and....we are back again with the flooding story !!!!
I just cannot catch a break here !!.......ps running with 26 /27 choke tubes.
I have changes jetting about the umpteenth time,.... and just cannot get a break here.
what say you ?
Posted: Fri Mar 25, 2022 7:40 pm
Hi Nick,
Is it not your surge pump on the carb that is delivering too much fuel as you open the chock.
Maybe disconnect it for your trails, and then work out when it should open, and change the swivel point to dial down the fuel delivery.
Posted: Tue Mar 29, 2022 9:24 pm
flooding is a bad needle and seat.
changing main and air jets wont do anything unless you are driving.
have you tried adjusting the stroke of the pump jet arm?
Posted: Wed Mar 30, 2022 12:55 pm
by Haans
Herman & Tony,.....pump jet I checked,......squirting ok. we removed carb and believe that the manifold "throat" is way too small and too close to the carb.
If needle &seat is leaking,.... would it not flood over the top of carb to outside ?,......this "thing" will idle the tank empty,.....no issue.......
So,......both removed carb & manifold will be on it's way to a "specialist" in Capetown to sort manif and jetting out on a flow testbench.
Do you guys know of this gent .
Regards. haans
