MrT
Posts: 511 Joined: Thu Feb 02, 2012 4:01 pm
Has thanked: 22 times
Been thanked: 9 times
Post
by MrT » Thu Jun 12, 2014 12:57 pm
allens1979 wrote:
Do any of you guys know where I can get a complete rubber kit for this car locally as well as the chrome trim for the windows, waterbead and side of the car?
Tx
For the rubbers you can try Pro-Auto rubber in Boksburg
http://www.proautorubber.co.za/ or Rubberite
http://www.rubberite.co.za in Pretoria.
You can import anything from ISP West, CIP1.com or
http://www.karmannghia.com
You can also try Grand Slam on the forum, they import from time to time.
62vwbeetle
Oil Seal
Posts: 493 Joined: Tue Apr 15, 2008 9:48 pm
What model do you have?: 62,66,69
Has thanked: 6 times
Been thanked: 12 times
Post
by 62vwbeetle » Thu Jun 12, 2014 6:39 pm
Try pro auto rubber they are JHB based Benoni actually they do toms for karman gha and it is good quality
allens1979
Posts: 10 Joined: Sun Apr 20, 2014 7:49 am
What model do you have?: 61 ghia
Post
by allens1979 » Fri Jun 13, 2014 7:23 am
Thank you guys, I spoke to Pro Auto Rubber and they have a kit.
Looking for Karmann Ghia Type 34 "Razor"
Current 61 Karmann Ghia.
Muderick
Posts: 2864 Joined: Tue Feb 19, 2008 2:40 pm
Has thanked: 42 times
Been thanked: 69 times
Post
by Muderick » Fri Jun 13, 2014 9:21 am
Hi Allen... you do know that its not the one you want with the opening for the chrome moulding right? Its a universal cal look type rubber that you need to cut and join yourself.
If you Ghia does still have the chrome in the window rubber, fitting the kit from Pro Auto will significally change the apprearance of cars around window area.
Muds
Old School or Bust!
allens1979
Post
by allens1979 » Fri Jun 13, 2014 11:52 am
Thank you Muderick, When I spoke to him he said they do the rubber kit for the C , T and Cal look. Currently I have no Trim on the car at all.
Thank you for the heads up I will re-confirm with them.
allens1979
Post
by allens1979 » Sat Jun 14, 2014 11:46 am
Hi Guys
Been digging through the car this weekend.
Was definitely Blue before the yellow.
The floor pan has to be replaced only took a pic of the one side not that bad but the other side looks rough.
62vwbeetle
Oil Seal
Post
by 62vwbeetle » Sun Jun 15, 2014 12:36 pm
They have for 2 types of chrome moulding and the plain California style rubbers
allens1979
Post
by allens1979 » Mon Jun 16, 2014 4:36 pm
That is correct 62Vw beetle, for the C type Moulding and the T type Moulding.
Does anyone know where the factory VIN plate sits on the Ghia ?
John Alves
Posts: 792 Joined: Thu Jan 31, 2008 1:06 pm
Has thanked: 3 times
Been thanked: 48 times
Post
by John Alves » Mon Jun 16, 2014 6:34 pm
allens1979 wrote: That is correct 62Vw beetle, for the C type Moulding and the T type Moulding.
should be under the front hood, there should another number stamped on tunnel at the gear linkage inspection cover.
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
allens1979
Post
by allens1979 » Tue Jun 17, 2014 11:04 am
Thank you John, I got the number from the Inspection cover. The factory Vin plates are gone cant find them in the front.
