My mid life crisis !
- RICKY-R69
- Clutch
- Has thanked: 13 times
Re: My mid life crisis !
I know that bus. Had a white V painted om the nose like a splitty. Had a nice Bullbar with the radiator. Bus was standing in Mokopane at an intersection for a couple of days. Helped the guy with a Peugeot 505 radiator, because his was leaking badly. When he started it up, the water spurted out of the expansion tank. So they towed the bus back to Joburg with a 1300 Tazz. He used the bus to transport pre-school kids. Had a very nice interior at the time.
- What model do you have?: 71 bay (I think)
Thats correct,, picked it up for 10K,, not sure on related prices ,, but the therapy is worth much more,, havent been this excited since the first time I was going to get lucky ! the interior looked good from far but was a half job so will be redoing hat as well !
- RICKY-R69
- Clutch
Did not want to sell at the time. Said he paid 25k for it. Gave me the nose badge and R250 for the radiator.
- RICKY-R69
- Clutch
Any chance I can get my radiator back then?
etch primer on to stop any rust,, now to smooth and touch up before primer!
- RICKY-R69
- Clutch
That radiator is one of the best.
- RICKY-R69
- Clutch
It stays your choice. Thing is, it is already mounted on the bullbar. The piping and hoses were made to fit. The fan was mounted. It is a nice big radiator so it should run cooler. There are a lot of controversy on the cooling systems but you can have a look on wwwmvwkd.co.uk. They got nice configurations on there.
I'm not planning to leave it on the front,, underneath or in the back with ducting
- beetlepower
- Twin Port
- Has thanked: 3 times
- Been thanked: 28 times
Are you Michael Creevy's dad?
0828378801
@reubenvn on twitter
0828378801
- RICKY-R69
- Clutch
I did the radiator in the back thing with ducting.The problem is with the low pressure system it forms behind the bus. Will go the under belly route next time round. Best then to use two golf radiators with primary and secondary fans.
@ Ricky, I have a few plans to either ducr from the front orthrough the sides, I think the main thing will be to do the ducting propper, considering running a viscous coupling/fan off the motor so that there is allway's air being pulled through,, will run my exact plan's past all you knowledgable people befor I do it though !!
