Split bus adjustable Straight Axle Kits finally done
Re: Split Window bus Straight Axle Conversion Kit
Quick Update
Basically all the Ducks are in a row with Planning and ordering the various parts from the Various vendors
I will be ordering the steel plate on monday to use for cutting the conversion plates so the kits are getting closer to the end result
herbie123
What model do you have?: a few
Been thanked: 4 times
Post by herbie123 »
Hi Pierre
if i may correct that slightly ,
The rear surpension has been changed with the following
Torsion arms , STD split bus
Torsion blades , 68/69 bus
IRS suspension arms , 68/69 bus
IRS , Beetle Gearbox , with longer 3rd , and top gear
CV shafts , 68/69 bus
Read brake drums etc , 68/69 bus , 5 stud 112 PCD
herbie123 wrote:Hi Pierre
fORSURE you may thats why I mentioned your bus as you have done it :D this info is actually valuable for fellow members and they can contact you if they need IRS conversions done
The steel plate is on the way to Water jet cutting guys so hopefully by Tuesday I will have the first plates cut for split bus and Beetle adjusting plates
Keep watching this space
75fleetline
What model do you have?: split window
Post by 75fleetline »
I might be interested too, keeping an eye on this!!
Due to the Public holiday Tuesday is everything on hay wire again and there are 5 vendors involve getting this project to work so just a little bit more patience and
It will be all worth it at the end of the day
I know it is taking a bit longer as my self would have wanted it but I rather get it done right the first time as I am getting a sheet of 2500 X 1200 cut up in to plates for Straight axle adjustable kits and making a few Beetle adjusting spring plates also
split
Post by split »
I would be keen on 2 sets if price is right...not happy with the job done on my 1st bus and have not tackeled the 2nd.Am busy with a split pick up but am using the complete backend of a bay which had jetta motor conversion.Was easier to cut chassis and join
I have Picked up the first 5 sets outer bushes that will have the splined part today they need to get welded in to the short piece for the adjusting plate
Also done a upgrade on the long goos neck plate it will also get a sleeved bush that will fit over the splined part for preventing the goosneck plat eating in to the splined bush
I had the drop also redused as I had it at first a 5 inch drop and having the plate sit on the std place which was far to much
I have brought it down to a drop of 3.3inches when removing the RGB`s which is what most of the aftermarket guys make theirs and spoke to some of the guys in the States
which recon that is good as you can still go lower and higher
so hang in there as the product will be worth while all the wait and cost elective
Re: Split bus Straight Axle Conversion Kit and Beetle adjust
Ok Got a slight update with some Pictures
I had the kit cut out of perspex just to check alighnment of the 2 pieces and the bushes and adjusting blocks that needs to be welded in
Hope you Guys Approve as this will be a better kit and less Expensive than the kits from the states and it will be adjustable
I am going to make one set that will be off set to use the short axles but they will be trail to see how they work as some of the guys want to fit wider wheels in the back
Lemme know what you guysthink so far :hangloose:
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Re: Split bus Straight Axle Convrs Kit and Beetle adjustable
Post by Donovan D »
:shock: :shock: :shock:
That looks really great !!
Adjustables are the way to go, its really annoying having to take everything off before moving the springplates. And getting the wheel back in is a struggle aswell when the springplates are set in the lowered position. Adjustables are so much easier
Great stuff Bugger !!!
Splitz wrote::shock: :shock: :shock:
Thanks Splitz I was looking at this project a while ago but was not financial viable till I had a Client that needed the Straight axle kit
But most of the kits in the States were only available with out adjustable and that in one of the motivational reasons I rather do My kit Adjustable
Hi Guys Thiought it was time for a update
The first set is finished
All bushes and braces and threadblocks welded up
Adjuster plate bushes Splined and Axle tubes Lengthened
Should have pics tomorrow
I am planning to fit this set to the Bus I started the project for first and check that Everything works out perfect before I put Manufacture the rest of the sets
that I intend to make
So just a bit more Patience and all will be worth while at the end of the day
MINCE
Post by MINCE »
be keen to see how much it will cost.
wonder if someone has the balls to make an IRS conversion kit, or is there a way to do it already?
MINCE wrote:be keen to see how much it will cost.
I got the balls but the cost will be to radical and not worth the effort as we do not have alot of IRS spares available in SA and that makes the rest of the conversion expensive
As mentioned I want to keep the cost down but I have also invested a few$$$ in to the project doing R&D
MINCE
Post by MINCE »
Fair enough bro. I did a search and there are a few kits around internationally.
Would be sweet.
Looking forward to the finished product!
Mince making the IRS kit is not a big deal but getting the Arms with the Stubaxle bearing holders and stub axles
Then on the Gearbox side you need to convert a Swing axle box to a IRS box
Here you need Side plates
Dif acrrier
IRS Side gears
CV Flange cups
Shimms for setting up the diff back lash
Clips under the CV Cups
C Clips holding the CV Cups on the TRansmission
The above list is very similair like CHICKEN TEETH if you know what I mean same as Rock king horse :bn: :lol: :lol: :lol:
BUT it is do able for alot of effort
