Which type 4 engine
Re: Which type 4 engine
I say no,others say you have to.
in a baja you can run with the stock T4 cooling tin... in a bug, you cant
- BUGGOFF
- Pushrod
Ive swopped my 1.8 golf motor for a complete 1.7 type 4 with complete fi system. Will this with standard tin fit in my late bay dc? Ferdi.
It should,I can't see why not.
- Ron&Gill
- Been thanked: 21 times
Can I make it fit into a T14? With original T4 tin, I mean. And if not, why not?
I know about the flywheel, I have a T1 flywheel.
Type 1 flywheel won't work on a Type 4Ron&Gill wrote:Can I make it fit into a T14? With original T4 tin, I mean. And if not, why not?
- eben
- Site Admin
- Been thanked: 54 times
Some cutting would be involved but I don't know the specifics.Ron&Gill wrote:Can I make it fit into a T14? With original T4 tin, I mean. And if not, why not?
You could always try an IMPI shroud.
- Has thanked: 45 times
- Been thanked: 208 times
There is a difference in the left rear tinware area. Think you could use a piece from a late baywindow engine there. Underneath that is where the compressor for the optional factory airconditioning goes. On the baywindow,the tinware is higher there (to make space for a bigger optional compressor.)"Ive swopped my 1.8 golf motor for a complete 1.7 type 4 with complete fi system. Will this with standard tin fit in my late bay dc?" Ferdi.
If fitted, the aircon was driven by a belt that ran in a hidden position between engine block and fan housing.
Have seen pictures in overseas magazines of t14 Karmann ghias with T4 with standard flat cooling system. Cannot remember how much space there was left between fan inlet and engine lid. Will have a look through old Hotvw/ VwTrends issues, will take time, (Have 2 boxes full of these magazines)."Can I make it fit into a T14? With original T4 tin, I mean."
Would be nice if the outer mating tinware could be cut out of a T4 car and fitted to the T14 KG.
By the way i had a 412LE fuel injected engine (80 hp) in my beetle back in 1977. Used standard flat cooling fan. Had to do a lot of cutting to make it fit. Used the fan cooling air intake funnel from a 412 sedan to scoop air from above,to prevent hot used air to enter. The engine lid could not close fully, but fitted over the intake air funnel, to help keep used hot air away from intake.
- What model do you have?: '79 & '04 Type 1
Besides which engine. Will any mechanic be able to fit a Type 4 Engine into a Type 1. I want a good Type 4 Engine (Don't even know where and what to look for) in my Type and don't know anyone who can do it yet? Price is a concern too by the way...
I am..... Rhino Horn Customs.
And Someone.... stole the voices in my head. I'm gonna find him...
And I'm looking for Yoda. IMPI. Need some advice here
the conversion alone will prob cost you more than the T1 engine overhaul... and thats without buying the T4 engine and getting it overhauled... whats your budget?
