'63 Type 1 aquired today :D
- Drive Train
Re: '63 Type 1 aquired today :D
Yup, that is the life of Aircooleds. Keeping them going
VW Enthusiast
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Pulling the motor to get at the Release fork, it moved and clutch stopped working...
Rgrds
Also managed to get some 6V light bulbs Rgrds
What other people think of you is none of your damn business
- sarel.wagner
- Pushrod
Pulled the motor this morn. Found the cir-clip tired and it got out, hence the shaft moved. More worrying is that the 2 clips keeping the release bearing in its place is nowhere to be found, wtf
Need 2 of those clips, chances are a new release bearing and a new cir-clip for the shaft. Pressure plate bent, is this ok? Rgrds
- JamesD
- Been thanked: 20 times
Those release bearings are hard to find, so just a warning. And yes, i would replace the pressure plate. if its bent then it will affect the balance and could cause uneven pressure on the clutch.
From fastest to slowest:
'75 SP 1600 with a few mods
- lowlight
- Been thanked: 14 times
bought one last week in Pta R175 I think. Midas across Jakaranda sentrum. No clips with
- sarel.wagner
- Pushrod
Fanx Blitzie for the You da man! Volkspares got stock Picking up later 2day...
Rgrds
Rgrds
- Klaus
- Has thanked: 13 times
- Been thanked: 11 times
Hey Sarel - again awesome ride
- Hijack - When you gonna put up some of the awesome pics you took at the Drift ?
- sarel.wagner
- Pushrod
Fanx bro did put up on the pictures post for KKKAK, but here is a link to all, full size
http://www.flickr.com/photos/sarel_wagner/sets/
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Busy fixin n replacin bits while the motor is out...
Rgrds
Sandy and media...
Painted tinware, genie housing cleaned up with sodabrade media
Works a treat....Rgrds
