Soda Blasting paint stripping
Barry
Re: Soda Blasting paint stripping
Post by Barry »
Frank, sorry don't have # handy- they're in Daniel St.# is 021 853 7862 (Just a little way past the Porsche/Audi/VW workshop on the opposite side) Speak to William for advice on any corrosion protection that may be neccessary.
Barry
Barry
Skipper
What model do you have?: Combi
Post by Skipper »
Dutch_Diver wrote:I have 3 roof racks that I want stripped and then powercoated.....2 for a beetle and 1 full length one for a bus. Can you strip them? Do you also know of a powercoater who can handle big stuff in Cape Town area?
Sorry just seen this, yes I can strip them for you
http://www.sasodablasting.co.za" onclick="window.open(this.href);return false;
http://www.fluidcorrosioncontrol.co.za" onclick="window.open(this.href);return false;
http://www.rustbullet.com" onclick="window.open(this.href);return false;
Barry
Post by Barry »
Hi Skipper
Any feedback on paint adhesion issues with soda blasting?
Barry
Barry
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Hi I use caustic soda diluted in water to strip paint from parts.
should you not rinse and wash (read: extremely thoroughly) you will have issues especially those nooks and crannies which holds the stuff. I normally wet sand the steel parts with soap and water as well. then there is no issues. problem is that this promotes rusting immediately once the metal is clean. Normally i use a degreaser made by Revet called SDR which contains a little bit of sulfuric acid (but still save for hands, the product was meant for the milk industry so is environmentaly friendly jada jada) then I paint and have no real issues but dont wash at your peril.
Regards
Skipper
Post by Skipper »
Barry wrote:Hi Skipper
Barry
As I said just wash the bi-carb' off thouroughly with water, let dry and then immediately apply your base coat
Bi-carb desolves and can safely be rinsed down the drains with no detrimental environmental effects, this stuff isnt the same as caustic soda, its rough grade baking soda
Hope this helps
Dave
clement
What model do you have?: 60 Vrod, 62 Crew Cab
Post by clement »
Hi Dave
Where can I buy Fluid Film?
Skipper
Post by Skipper »
clement wrote:Hi Dave
The closest outlet to you is Safari and Outdoor near Klapmuts, or direct from me
Barry
Post by Barry »
Interesting reading for anyone using soda blasting:
http://spi.forumup.org/viewtopic.php?t=156&mforum=spi
Barry
Skipper
Post by Skipper »
Barry wrote:Interesting reading for anyone using soda blasting:
Yep, the guy said the surface has to be prepped/cleaned after soda blasting, the soda has to be thoroughly washed off as it does leave a protective film on the metal.
We always rinse off with a high pressure water jet, this maybe why we have had no comebacks so far :wink:
