Re: '59 finally getting sorted to be a daily runner
Posted: Tue Aug 04, 2009 4:31 pm
by Chris
Btw,I do have a radio blanking plate.
Posted: Tue Aug 04, 2009 4:48 pm
by dsan
Thanking you yes please!
Posted: Tue Aug 04, 2009 4:55 pm
by Chris
PM sent
Posted: Tue Aug 04, 2009 7:17 pm
by Bugz
dsan wrote:Electrical Update
The previous owner did such an abortion with the wiring, it is being stripped out and redone. This will include:
New Bosch fuse box
New wiring all over
Semaphores wired up to separate switch
rear snowflake lights working as single light/brake and indicator
anti-theft breaker unit installed
All cable in the bonnet will be neatly channel and housed in aircraft style wiring harnesses
The rear light issue has been a problem. Ideally i wanted both the semaphores and rear indicators/front indicators to all function at once, but that won't happen. This is the best compromise we can come up with.
Heej man, does that guy wants some more bussiness? (Auto eleccy ) Where are they based? Looking for an electrician that can clean up my abortion..
Posted: Tue Aug 04, 2009 7:26 pm
by dsan
He's a good find. Older guy who retired from doing airplanes and what not and now has a big workshop at his home to keep himself busy.
Loves older cars and is really anal about wiring and doing it right. He's based in Durban north
Posted: Thu Aug 06, 2009 1:39 pm
by dsan
Movement on the wiring front.
All the old loom has been removed, as has any other electrical wire found inside of the car. He has rewired the rear snowflake lights so they now function 3 ways and at the same time modified the indicator stalk to activate the semaphores. The interior light is also being sorted, which will make a nice change
Still loads to do, but it's moving at a nice pace.
Posted: Fri Aug 07, 2009 12:00 pm
by lowlight
Please tell us how he managed to do the snow flake 3 way.
Posted: Fri Aug 07, 2009 12:03 pm
by dsan
If I knew i'd share.
He drew up the plans last weekend and did some tinkering and finally came up with an approach that worked. I'll ask him when I next pop round. The nice thing is that he isn't expensive, so could do it for you as you seem to be local
Posted: Sun Aug 16, 2009 11:03 am
by dsan
Bah always something to slow the project down. Turns out the previous owner lost the speedo lights for oil/ignition and indicators, so we are now trying to source some in durbs to finish off the wiring.
The rest of the car has been rewired and neatly cabled.
Images to follow tomorrow
Posted: Sun Aug 16, 2009 8:02 pm
by hitlers revenge
Those lights are made or Unobtainium. I want to do like on "the samba" - search LED's.
Posted: Mon Aug 17, 2009 3:10 pm
by dsan
Found the bit I was looking for, ok so it cost 100 bucks but it's needed
Wiring is nearly complete, the new loom has been added, the old loom that runs in the roof has yet to be removed by as it standards right now, the whole car has been rewired and just requires a little work to tidy all the connections up now.
progress...
Posted: Fri Aug 28, 2009 4:09 pm
by dsan
Light at the end of the tunnel...
Wiring complete, just handed over 5k for the complete rewire and modifications to the rear.
The bonnet area looks amazing now
All wiring was removed and replaced. This included all engine related wiring, so alternator/oil pressure switches now work.
The rear lights now look f**king amazing
Tomorrow we strip and prepare for the re-spray.
Posted: Fri Aug 28, 2009 9:35 pm
by karmakoma
Looks great!
Posted: Sat Aug 29, 2009 6:05 pm
by dsan
Stripping and prep time.
I figured the more I take off, bag and note, the less they can loose/damage whilst getting painted.
Nearly had the front wings off except for 1 bolt that holds the cable pipe that wouldn't budge.
Only 4 sheared bolts during the whole process, which isn't bad.
Posted: Sun Aug 30, 2009 4:33 pm
by johanb
I like your indicators... All the best with the paint shop
