Page 2 of 2
Re: MORE POWER!!!
Posted: Fri Mar 19, 2010 3:25 pm
by IMPI
Dyno work I have done on actual engine showed between 25 and 37 kilowats for std engines
43 kw for std engines with SP carbs and nice 4 into 1 exhausts
50 t0 56 kw for 1700 411 engines with only 36 idfs added
55 kw for 1800 (76.4 x 87)
60 kw in a beetle will really wake it up and will be beyond its std brakes.
Add a turbo and a 66x101.6 type four with only larger valves will make 137kw
Re: MORE POWER!!!
Posted: Fri Mar 19, 2010 4:02 pm
by Blitzkrieg
I live in regret.
To quote IMPI from an email sent in 2007:
"If I may make a suggestion, build a standard 2.0 Type 4 and add a Gotech or similar. That way, you can add a turbo at a later date and make lots of power..."
If I only had to follow this advice back then, I would have had a monster of a ride
Re: MORE POWER!!!
Posted: Fri Mar 19, 2010 10:54 pm
by Ron&Gill
IMPI wrote:Dyno work I have done on actual engine showed between 25 and 37 kilowats for std engines
That 60kW you get from 1914cc with Engle 110 cam and 041 heads and 2x 36mm IDFs, on the dyno. And yes, it wakes the motor up big time. Mine's in my buggy. And 189Nm
Re: MORE POWER!!!
Posted: Sat Jul 17, 2010 10:20 am
by Junior
how much did you pay for your carb set up?
Re: MORE POWER!!!
Posted: Sat Jul 17, 2010 10:36 am
by Ron&Gill
R1500-2000, can't remember... I did mine in stages anyway, so it's hard to estimate. I have a price list from flat4racing, but can't find it right now.
Re: MORE POWER!!!
Posted: Mon Jul 19, 2010 6:44 am
by dubster
can i bring in another one?suby 1800 turbo (ej18t) i saw them for 4k and the make 150hp (110kw) in stock form,spitronics have a ecu for them @ 3,8k...now the groot vraag?what does the adapter cost and radiator and piping?
