Page 2 of 2
Re: A Rhino is being Born
Posted: Fri Jun 26, 2009 6:56 pm
by ZeroAxe
The secrets are about the internals no? Not about cleaning??
Posted: Fri Jun 26, 2009 8:26 pm
by Bugger
ZeroAxe wrote:The secrets are about the internals no? Not about cleaning??
NO YOU are wrong
The cleaner it is the stronger it is
I Have a old
Posted: Fri Jun 26, 2009 10:10 pm
by ZeroAxe
I read your post about 10 times, and am more confused now than the first time I read it.......
'n Man van min woorde, jy is!
Posted: Fri Jun 26, 2009 10:33 pm
by Bugger
I do not know what happend to the rest of the post
Hy is gesteel
I have a mix of Costic soda that I leave the trannies in after I have taken most of the "GHRIES" and slug off it on the out side.THen I also first clean off most of the Old Gear oil that has made a slug on the inside of the casing, other wise the Coda gets to contaminated with all the Oily things in the tank
I leave it to soak there for half a day and then IT gets the Steel brush and Elbo ghries job to get it looking like nae
If The Casings were painted by 2K Paint then it is nearly 3 days hard graft to get it clean with the help of Paint stripper and lots of swearring the guy who painted it
I will only be getting back some of the machining on Monday
But I might be starting to assemble the Main shaft and Pinnion Shafts in the mean while if I get around to it this week end and take some more interresting Pics of that
Posted: Mon Jul 06, 2009 10:38 pm
by PhantomPhondler
excuse the stupid question but why is a rhino case called a rhino case?
i like must I add to the website master crafter bugger?
Posted: Tue Jul 07, 2009 1:00 am
it is a stronger than stock case... called rhino because thats how CB markets it (as in their catalog), all their heavy duty items are called "Rhino this" or "Rhino that"
Posted: Tue Jul 07, 2009 2:52 am
by buggyfan
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahh rhino horn!!!!!!!!!!!
Posted: Thu Jul 09, 2009 10:03 pm
by Bugger
PhantomPhondler wrote:excuse the stupid question but why is a rhino case called a rhino case?
Yes you may
I have picked up the one casing that got the through hole mod to pull the casing HD side covers together from the engineers today will be updating on this thread again as I get stuck in to the Twins
Posted: Sat Jul 18, 2009 7:16 pm
by Bugger
Ok time for a update
The pic below
!st gear to the left then to the right of 1 you guesst right 2nd then 3de and 4th gear.
With their respective Syncros to the bottom of all the gears with the Mainshaft above all the gears and the reverse gear
I have managed to source VW Brazilia Syncros for 1st 3de&4th gears the syncro for 2nd is a German Quality that is Quite Scares.You can see the colour differance and tags on the outer edges
These main shafts are really strong and durable, I have had a set in Flag buggy and did Reverse 1st gear wheelies with Mickey thompson Drag slicks.Aswell as very hard launches from the line at Tarlton.
On the Performance Transmissions I also replace the Copper type selector forks to the Steel type selector forks
Ihad one guy that brought me 3 transmissions to repair and all 3 of them had the copper forks been broken with other faults
These are the old 4 bolt type Pinnion roller bearings which are nearly henns teeth to source new German Quality ones. With the Mainshaft bearing to the top of it
Picture of the inner Casing where the Pinnion Bearing goes
Posted: Tue Dec 01, 2009 2:01 pm
Updates please!!!!
Are they finished or still under construction?
Posted: Tue Dec 01, 2009 3:08 pm
by Eugene
Bugger wrote:....So you guys can fire away some Questions and I can answer some of them
Sorry guys....the first question should be "WTF is a Rhino box?"
Posted: Tue Dec 01, 2009 4:54 pm
by Bugger
SambaOwner wrote:Bugger wrote:....So you guys can fire away some Questions and I can answer some of them
It is a Hevy duty aftermarket Transmission casing Used for high HP motors and some DRag racing
No Tony after this comming weekend I will be getting stuck in to the 2nd one to finish it and a Performance one for a Turbo Ghia aswell
The other one was installed in to the Orange bug and been Test driven and it changed Very nicely
Posted: Tue Dec 01, 2009 5:28 pm
Come on Samba... that same question was asked on this same page
