Rotary into bug/bus
- What model do you have?: caddy
Re: Rotary into bug/bus
What would the cost be to install a N/A carbed rotary motor into a D/C Bay window bus?
Bugger wrote:dubster wrote:So i have seen,id like a acvw oneday but if i cant resist the speed bug i might pop in a rotory...can always go back...what is a ballpark figure for a rx turbo motor in a buggy?
R30K with the Microtech radiator etc
Yes, i saw this.
But i mean a carburated motor into an already watercooled vehicle?
Now it is not easy to always predict a costingBugger wrote:Racer-X wrote:How about if u swap a rotary into a watercooled bus?
would it be slightly cheaper coz the waterworks are all there?
Yes then you just need to build a back cross member to hold the motor and tranny in place
Reason why your perfect install is not my or the next guys perfect install
I am busy with a Rotary that was already in a bug
I HAVE Removed all the wiring, Brackets and closed all 5000 holes that was drilled with Resin
Will start a thread About this one and the Rotary Puma getting Born
So to sum things up shortly
Radiaror system +- R5000
Microtech +-R9800
Basic complete install around +_ R30K
Now with out the Radiator and EFI you could do it for around R15000
But now you need a more Complex exhaust system R1500
You need to buy a N/A Intake manifold and Carb Not laying arround either R2500
If you are a hands on Guy alot of the Fabrication and Boermaak `n plan things you can Save huge amounts of money
When I do a conversion I either do it and charge for the Extra hours that I spend on the Car
or I rather Only supply all the bits and Pieces that the guy need for the conversion as not all has the R30k + to fork out at one time for a complete conversion
- Croaky
- What model do you have?: 62 71
Hi guys -
I am in the very early stages of doing a rotary conversion on a beetle (I bought a '71 in running condition, body so so, pan great) and would like to know how much Pierre would charge if all the bits and pieces were supplied?
Thanks in advance!
Thanks in advance!
Mail me at
buggerATtelkomsaDOTnet
Then I send you a list of everything you need and costings
Also just visit the Introduction thread in General discussions and say hi to all the other guys PLS
- Croaky
Hi Pierre, intro done and email sent.
I will try call you in the morning sometime to discuss my options.
thanks for the reply!
