Started Milly last night & disaster, engine oil spraying everywhere, went to bed a bit stressed out luckily today no jobs came in so My M8 Erik & I took a look couldn't really see properly so I towed Milly with the T4 down to ATS (I know the guys there & they let me use the ramp, they don't normally but this was an emergency) It turns out I had split the oil filter housing trying to remove the old Ol filter.
I called in FBI & luckily Graham had one & he took it off the engine for me. Called in GSF for a gasket kit, then back to ATS, stripped the engine to get off the housing. We had to remove 3 pieces of top tin, the fan pulley, the alternator, the oil fillr neck top, alternator tinware fan housing, oil cooler exhaust & heat exchanges.
So far we've refitted the fan housing, pulley, alternator & tinware, top tinware, v-belt new housing & gasket, the oil cooler with new rubber seals, just got to re-fit the exhaust, heat exchanges, fan guard timing mark plastic & a few screws. Hopefully I'll get it finished in time for Bristol tomorrow.
Here are few more pics of the exhaust & heatexchangers. They have had one st coat of silver since then:-
This is the high temp sealent I've used on he heat exchangers, its over paintabe so now you can't see it.
