OK so its been a long time since I updated the Project side of this thread.
And as I was keeping the progress quit before the Sani trip, as I wanted to get the reaction from the "Old School Boys"before letting the cat out the bag.
As you all know my feeling about driving a stock split bus, and having finally had Sean confirm this as being fact, even though he said he would deny saying this ..
but yes, it is most unpleasant driving a split for more then ten kilos.
So as I did want a split, because I like the design, and always wanted one as a kid, got this badly scrap body and worked it to my desired daily driver.
To bring you all up to speed, if not wanting to read the whole tread, these are the personal changes made to the bus.
Must say at this point...... I have retained all the original parts, and panels removed, or cut out, or changed, so the next generation can put the bus back to original in the future.
We cut out all the rust and redid the body back to original.
The Back has a Rock & Roll bed fitted
The front had the seat brace wall removed(and stored) and a "Flip-over-seat " fitted (so the seat can face forward or back when parked) ,
The front seat base is hinged so the spare wheel is housed under the seat, with the jack and all spare parts.
The front beam was removed (and stored), and replaced with an late bay beam, with the big disk brakes. (cut the beam, not the bus, so can change back)
Fitted brake booster with vacuum line from the motor.
Removed the split steering box and rebuilt it completely, and returned it back into the bus.
Fitted new drag arm, and all other linkages.
Replaced the ball joints, but drilled each with 6mm taped hole and fitted grease nipples.(this will prevent the ball joints from wear.)
Had adapter plates made to refit the wide 5 rims back onto the front wheels.
Fitted a 1914 cc Twin port type 1 engine with twin 34 ICT weber carb's.
Oh and yes, I fitted a raised bush on the steering column, and fitted a small Golf steering wheel, so my driving posture is not so bent over.
Now I hear you all ask.... as One Choir ..." and how does it drive now"..
Well it s magic, drove 3000km with ease, no back pain, no discomfort, just pure bliss.
Drives better then the Bay, nice seat space, and power with the reduction boxes mixed with the 1914cc motor gives all the grunt needed.
As I did not tell you, the engine has a balanced welded crank, so can run at 120 km should I want to.
The last thing was the 3 beetle bumper I adapted to fit the front of the bus.
This needed to fit the look of the raised bus, as the original bumper would not do it justice.
Yes I did not have one to start with, but as the Fleetline bumper, miraculously changed from Fleetline to Beetle during transport from a VW enthusiast
and I had two beat-up beetle bumpers already, I did a bit of cutting, a bit of welding and a bit of fitting, and it came out looking very butch, fits the bus to a "T"
In true Herman style ..
Well as i drive it more, and enjoy it more every time, I am happy with the final result.
Am just looking into drop spindals, and will see what it looks like with them fitted, maybe, maybe not will see.
So now you up to date, and we will post any other changes should these be made.
Thanks for looking
