- Wentzel
- Has thanked: 6 times
I have been looking at the heads and valves. Valve angles have been re-cut to proper angles and I'm replacing all the exhaust valves to be safe. Heads getting some clean up and work to the combustion chambers. Next I will have to source 90.5mm rings and hoping to re assemble the engine by the weekend.
Oxyboxer Project
- Buggslife
Condensor let me down in dunes on Sunday!
- Oil Seal
- Has thanked: 13 times
- Been thanked: 9 times
Decided to replace the oil seal behind the flywheel
Old vs new
The new one is apparently better because its "vitron". We will see
Old vs new
- Riekert
- Camshaft
- What model do you have?: 1964 Notch
- Has thanked: 111 times
- Been thanked: 23 times
Brought the notch back to my house after being in storage for ages!
Also had a quick look at the wheels
Not feeling it.....Rostyles with a nice slam would look epic
- Riekert
- Camshaft
Well currently has a deepdish rostyle on. Going to sandblaat and respray them. Will take pics when done
- Riekert
- Camshaft
started fixing the floor last night
. Hopefully have it done tonight.
- Wentzel
Playing around with Rocker geometry on the 1.25:1 ratio rockers to determine spacing and push rod length for my 1776. Hope to get it set up properly and get her running even better!
Oxyboxer Project
jetting, jetting, jetting
getting there....
getting there....
- Buggslife
Fitted a custom rear "recovery" cage/bar.
You JET-SETTER you..........Tony Z wrote:jetting, jetting, jetting
getting there....
- Buggslife
Like the colour! !!!Bugger wrote:First coat of paint on Speedweek beetle
- Buggslife
Played in the dunes today and took 2 extra condensors with to avoid disappointment like last time. Well I used up both spares and was towed out again.
Looks like Flat Four Racing gonna see me shortly for a electronic setup!
