Page 8 of 15
Re: 1964 Notch - The green goblin
Posted: Fri Jul 11, 2014 9:58 am
by beetlepower
51splitfanatic wrote:Green goblin's owner,
Jong the tjorrie looked so sweet with the rostyles....not sure about those more modern wheels, but they are still old school. I would search around for a set of Sprintstar wheels and make them 4.5j using the hoops from the Rostyles you have. This way you will have that nice tucked in effect(Wheels in the acrches) and the nicest wheels ever made by Lemmertz vw. Just my 5 cents.
I own a two owner 64 Notch in sand beige and currently running the 145/60/15's in front and 165/65/15's in the rear and all rims are Rostyle. Notch runs a few inches form the ground in front and serious camber in the rear. People duck when they see the car coming....they are thinking Mexican Mafia and driveby shooting at the same time...ha ha!!! I am currently busy with a set of Sprints that I have in my collection that I am making 4j in front and 4.5j in the rear....they will beb fitted to my stufenheck(Notchback) very soon.
Kind regards,
51 Splitfanatic
Ant pics mafia man?
Posted: Sun Jul 20, 2014 11:14 pm
by Riekert
So... 10 days later and the goblin is back at home after its long time in storage.
Did 35mph behind my tow mate coming home... was interesting
Started by quickly snapping a pic of the wheels I want to fit.
Looks good imho. But for now wheels go back in storage.
So started fixing the floor today. Want to finish it by tomorrow night quick. Then onto the rear brakes.
But that's it for now
Posted: Tue Jul 22, 2014 12:29 pm
by Riekert
So floor almost fixed. Finishing it tonight.
Posted: Tue Jul 22, 2014 8:18 pm
Good to see the Type 3 project on the move again.
Keep the info coming...
Posted: Tue Jul 22, 2014 10:50 pm
by Riekert
Thanx!
So floor is 99.9% done. Just needs another coat of paint. But battery tray is now nice and strong. Will still redo the pan at some stage... but not now. Just want to get it running.
tomorrow night will be time for the rear brakes. Need to take them apart and see where the leaks are. Then... refitting all the motors parts again and motor going in this weekend.
Now I've got a tiny problem... need to get my geni redone.
sigh... so will get that done month end. Well that's it for now.
Posted: Thu Jul 24, 2014 9:39 am
by Riekert
So... no progress yesterday... had house duties
. but got some Enige bolts Yesterday.
Hopefully they will work. M10 1.5mm thread 8.8HT. 100mm long.
Tonight I'm putting the tinware back on the engine and putting the carb back on too.
This weekend I'll jack it up to do the rear brakes.
Posted: Sat Jul 26, 2014 8:15 pm
by Riekert
So this weekend so far was a bust... house sitting so can't do anything
well put most of the engine tinware back just the back panel. Then carb and coil. Bolts fit 100%. So will try fit the motor tomorrow when I'm home. Progress is progress I guess.
Posted: Wed Jul 30, 2014 7:02 am
by Riekert
So no motor fitted yet :+ but getting there. Carb is back on and tinware too. I've also stripped the geni. now I need to get new bushes, derust everything and get 2 new bearings for the front and back. Also does anyone know if you still get the inside coils? The ones bolted to the side of the geni?
Anyhow. Will try and get the motor in this weekend :/
Posted: Wed Jul 30, 2014 9:13 pm
Normally the coils in the Genny do not give problems, the insulation may break down, but the coils should still work.
You can dip it in Insulating varnish, or have used oil paint in the past.
If its a small patch, you can seal it with rapid epoxy, the twin tube mixing kind.
Posted: Fri Aug 01, 2014 10:57 pm
by Riekert
Thanx! Retrovan
Well seeing as I broke my leg today the fixing of the notch is gonna be a bit difficult
Posted: Sat Aug 02, 2014 6:44 am
eina... that doesnt help things.
Rest up, get better
Posted: Thu Aug 07, 2014 8:32 pm
by Riekert
Thanx tony... and I'm going to be 1/5 ironman now
plate and 3 screws I'm my ankle :'(
Posted: Fri Aug 08, 2014 7:27 am
Its not so bad... I know people who cant get any screws no matter how hard they try
Posted: Fri Aug 08, 2014 9:47 am
by Riekert
Hahaha.
Posted: Wed Aug 13, 2014 4:35 pm
by Riekert
So wasn't 3 but 8 screws 0.o
