My Buggy - More Pics
JohnHoffe
Post by JohnHoffe »
And no, Clare is not a giant kid, she's only 4 years old......
Re: My Buggy - More Pics
That is one sweet buggy....
Engine specs?
JohnHoffe
Post by JohnHoffe »
How much money do you have?
Not going to buy it.... and dont care that much to pay either...
That car looks like a monster.
JohnHoffe
Post by JohnHoffe »
Type 4 with the majority of it modified. 2309cc, twin spark (bitch to change the bottom plugs), S/S valves 48 & 38mm, MicroTech management, 40mm Precision throttles, 500cc balanced Weber mini injectors, FK89/90 cam, counter weight crank, slim flywheel, valve springs, chrome moly retainers, push rods, Clutch Master clutch, Bugger 'box, etc. etc.
JohnHoffe
Post by JohnHoffe »
Only a monster on the wallet.....
lowlight
Post by lowlight »
I believe you.
One very cool ride!!!
JohnHoffe wrote:Type 4 with the majority of it modified. 2309cc, twin spark (bitch to change the bottom plugs), S/S valves 48 & 38mm, MicroTech management, 40mm Precision throttles, 500cc balanced Weber mini injectors, FK89/90 cam, counter weight crank, slim flywheel, valve springs, chrome moly retainers, push rods, Clutch Master clutch, Bugger 'box, etc. etc.
Nice one.... why didnt you go bigger on the throttle bodies?
I think you have more than enough "krag" in that black monster.
Love the look of the front with that clear cover.
is it my imagination or have you got drum brakes on all 4 corners? Very brave man
JohnHoffe
Post by JohnHoffe »
The ports are at about 41mm, the intake valves at 48mm (clever people say a ratio of 1.2 to 1 (valve to port)is correct), so it made no sense to go for 45mm throttles.
When I put the motor together on paper I tried to keep everything balanced, i.e. Ram air tube to throttle to port size to valve size to header size to collector size. I tried to avoid the concept of "as big as possible"...even though everything is quite sizeable.
Yes, there are drums all the way around. The day I can find adapters for my 911 calipers and rotors I'll fit them. Any ideas? :?
Bad Ass Bob
Post by Bad Ass Bob »
John speak to Split fan he has done some thing to his bus with Porche brakes, might be worth your while................BAB
AirPower
Been thanked: 4 times
Post by AirPower »
Wow - that is one MEAN Buggy. I like that a lot, it just looks fast even when standing still.
What did you do to the front windscreen? lowered it? Do you still fit behind it or are you getting bugs in the beard? :D
Still that looks awesome
Mario :hangloose: :hangloose:
