What IMPI
Guest
What IMPI
Post by Guest »
What does IMPI stand for and more specifically from which car does the 1700 IMPI originate?
Merlin
Has thanked: 20 times
Been thanked: 39 times
Post by Merlin »
IMPI is the nickname for Armand Botha's 'experiments'. :)
It doesn't originate from any car.
Armand takes Type 4 engines - mostly - and then goes Nuts with them until you get a fire-breathig monster under the hood. :mrgreen:
IMPI is a ripoff of EMPI.
N.
Guest
Post by Guest »
Ok, what is a T4 engine. Since it appears that this is modified into the IMPI? :?:
Merlin
Post by Merlin »
Type 4 is a VW model.
They are flat 4 cylinder engines which are usually converted to stand upright and then placed, albeit with mods, into bugs and bus'.
Google 'Type 4' for a pic...I have none handy. :)
images.google.co.za
N.
Hi Fergus,
this is a type 4 turbo engine.
As you can see the fan housing is in front of the engine and not on top like in a beetle (type 1)
Type 4 engines came out as 1700, 1800 and 2000
they were used in the later type 2 busses(Called Bay windows cos they have curved windscreens) as well as in the Porsche 914.
Main difference appart from capacity and cooling is the addition of an oil filter as standard, a quite bulletproof crank and crankcase and rigid(non concertina) pushrod tubes....
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Hi
IMPI Yes some rip off of EMPI but also unique in SA as the ZULU word for War
Impis = Zulu footsoldiers yeah
WestyT2
Post by WestyT2 »
Vw Type 1 Beetle
Vw Type 2 Transporter/Microbus/Kombi
Vw Type 3 Vw Sedan Notchback/Fastback/Variant
Vw Type 4 Vw 411/412
The Vw Type 2 evolution
T1 Splitscreen Van
T2 Bay Window
T3 Wedge (example 2.1i,2.5i,2.6i) Also known as Vanagon or T25
T4 Previous range
T5 Current Kombi/Caravelle/Crew Bus
The Type 4 engines was used in the 411/412 and the T2/T3 Microbus in 1700, 1800 and 2000 versions.It was also used in the Porsche 914 (and 356 if I remeber correctly) . It uses a bigger more durable aliminum crankcase than the type1 but spares are generally more expensive and harder to find than type 1 spares. Hope this helps,Fergus
The best reason for doing the right thing today is tomorrow
Type 4 engines were used in the 914 and 912E models.
Class 11 streeter
What model do you have?: 8.5 Beetles!
Post by Class 11 streeter »
Sorry I am late to this party. My friend Tom (known as Tuna on Samba and ShopTalk) has a site with lots of type 4 engine info:
http://www.tunacan.net/t4/
That site encouraged me to convert to type 4. Right now Eddie Brown is building me a putt-putt 1.7 (out of a 411) converted to upright to put into my offroader class 11 bug.
It's has been a long road up to this point, several years in the making, but it will be worth it............I hope............ :shock:
I don't know it all, just enough to be dangerous!
