Bugs: converting from disc back to drum...
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
...as the topic states, I'm thinking of converting my '67s disc-mod'd rear back to drum...how hard is this to do? Do I just replace the beam, etc. or what?
- Has thanked: 4 times
- Been thanked: 98 times
Why would you need do do that ???? If you have to then it should be a swop over no problem, you would only need to check if you have short axles or long axles. If I recall correctly you have IRS so you will have long axles, then 4x130 PCD beetle drums & backing plate will bolt on, if you intend on going this route we can talk a deal cause I have a set of drums that will fit your 4x130 PCD wheels, let me know.
- Merlin
Hey calooker,
At this stage it's only a thought...
Quite frankly I'm not sure why I'm thinking of doing it, I 'spose it's more of a curiosity...
This bug is not IRS, I turned that IRS chassis down as it needed major rust repairs.
Cheers, N.
Cheers, N.
