suicyde engine
i can see clearly now :D :D :D
dID NOT CHECK P3 YET
still waiting to see if pg 3 works.....
Bugger wrote:Hey I`m curious ????
I wont spill the beans. Its staring you right in the face, but far from obvious. If you get it right, I'll buy you a few drinks, if not, just keep guessing
can anyone spot anything odd about this assembly????
easiest pic to pick it up in...
other pics it can be seen in
Something to do with the pistons clearing the crank :?:
wtf
I expected better from you.... you'll kick yourself when you realise it... 1 item in specific that isnt found very often
AirPower
Been thanked: 4 times
Post by AirPower »
Counter weights? or is it counterweights?
normally she be like siz:
any engine with an 84mm stroke should have counterweights. If you buy a R4500 crank without counterweights, you need a kick in the ....
Good try though
SUZIE
Post by SUZIE »
I sit maybe the conrods?
SUZIE
Post by SUZIE »
or what is that copper gear in the front for?
thats the timing gear that drives the dizzy....
By a process of elimination, I am sure you'll eventually get there, but then you have to tell me whats so different / special about it :lol:
SUZIE
Post by SUZIE »
O comeon Tony, this is teh first time in 20 years that i see a open flat 4 engine of VW, so you need to be a bit more specific, even if it is just for me
SUZIE
Post by SUZIE »
Tony
I am trying to eliminate the parts here
is it to do with the cranc?
is it to do with the block casing?
is it to do with the cam?
SUZIE
Post by SUZIE »
Tony , did you knife edge the crank?
The VW doesnt really need its crank knife edged like a V8. The V8 has the crank sitting near to the oil level, so knife edging helps when the webs hit the oil... the VW has the cam just above the oil level.
Suzie, if this is the first time in 20years you are looking at an open VW flat 4.... then I seriously doubt that you will get it.
My money is on someone who rebuilds these engines regularly....
You can see it in all 4 pics
