Splined casing nut?
VW-rules
What model do you have?: 1961 Bus
Has thanked: 10 times
Belgium
Splined casing nut?
Post by VW-rules »
Hi there. It's been a while since I was last here :shock:
Quick question. Of the 4 engine mounting bolts, two are at the bottom, one comes through from the starter motor and the 4th bolt screws into a splined nut that is pressed into the engine case. What is that 4th splined nut called and where can I get one?
It's a bitch trying to use a regular nut on there. Thanks. Cheers.
Has thanked: 45 times
Been thanked: 208 times
Re: Splined casing nut?
Post by Dawie »
Like dual port engines have, offset oil cooler in the way there?
Something like this?
https://boltandnut.co.za/product/10mm-a ... ge-flange/
Might be called "clinch nut" or "press nut" or "pressed nut". For use in magnesium type 1 casing application i would image a wide flange version would insure best support.
AlanH
Has thanked: 126 times
Been thanked: 86 times
Germany
Post by AlanH »
Also known as rivnut. Can't say I've seen that on my bus.
Wanted parts:
Left sunvisor
Sink faucet
I dont think you can buy those particular nuts loose.
Its a splined nut the is inserted into the case with a press fit - kinda like splined wheel studs.
Just leave that particular bolt/nut off and keep the other three.
I know of at least one engine with over 100hp that only has the three installed.
VW-rules
Belgium
Post by VW-rules »
Thanks for the pointers every one.
