Split crewcabs with airboxes
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
Hi everyone,
I'm looking to make contact with anyone with a split crewcab that is fitted with air boxes, please.
It must have air boxes, not the German-style vents.
I'm looking for assistance with some measurements.
Thanks.
Thanks.
- Has thanked: 42 times
- Been thanked: 207 times
Re: Split crewcabs with airboxes
Can help you with dimensions and pictures from a 66 crewcab with original Uitenhage-made air intake boxes.
- Merlin
Thanks, Dawie.
I sent you an email via the forum over the weekend.
Please PM me your mobile number.
Did not receive your email. Might be an issue somewhere.
Sent you a pm earlier today.
I keep watching my pm's. No reply from you so far.
- Merlin
Thanks, Dawie.
Only logged in now.
I've sent you a WhatsApp message.
Only logged in now.
- james309
- What model do you have?: Crew Cab
I have a crew with rear vent intakes.
Sent from my SM-S906B using Tapatalk
- Merlin
Thanks, James.
Dawie very kindly provided me with measurements and photos. I'll be in touch should I need further info'.
Riaan, airboxes were used in southern Africa in an attempt to reduce the intake of dust. They sit higher up than the common intake path.
- james309
Ive only ever seen a couple. I believe there were a few variations on crew cabs.Riaan.N wrote:This is interesting, haven’t seen this before.
Why is this different from the ‘usual’ vents?
I have a single cab that has the intakes on the back of the cab, with the airbox running under the bed.
- Merlin
To the best of my knowledge, they were unique to this part of the world.james309 wrote: ↑Sun Aug 27, 2023 2:19 pmIve only ever seen a couple. I believe there were a few variations on crew cabs.Riaan.N wrote:This is interesting, haven’t seen this before.
Your cab intakes were likewise for use in dusty regions.
- james309
As far as im aware were for dry/dusty climates. Africa / AustraliaMerlin wrote:To the best of my knowledge, they were unique to this part of the world.james309 wrote: ↑Sun Aug 27, 2023 2:19 pmIve only ever seen a couple. I believe there were a few variations on crew cabs.Riaan.N wrote:This is interesting, haven’t seen this before.
A few different variants depending if german built or CKD
