My other project cars
- Been thanked: 539 times
Re: My other project cars
- V6 Capri
- Has thanked: 7 times
- Been thanked: 29 times
Would this be Rowland?Haans wrote: ↑Wed Mar 30, 2022 12:55 pm Herman & Tony,.....pump jet I checked,......squirting ok. we removed carb and believe that the manifold "throat" is way too small and too close to the carb.
If needle &seat is leaking,.... would it not flood over the top of carb to outside ?,......this "thing" will idle the tank empty,.....no issue.......
So,......both removed carb & manifold will be on it's way to a "specialist" in Capetown to sort manif and jetting out on a flow testbench.
Do you guys know of this gent .
Regards. haans
1964 Ford Anglia 997cc
1972 Ford Capri 3L GT
1996 Escort 2L Zetec
2016 VW Touran 1.6TDi
1971 Baywindow project
- Has thanked: 42 times
- Been thanked: 207 times
There was'nt perhaps an electric fuel pump fitted recently?
- V6 Capri
That could very well be it. What is the fuel pressure that the pump supplies?
- Camshaft
- Been thanked: 107 times
Gents,..car came with facet pump and 38 DGAS,.....and now with 36 DCD7.
Measured pressure at carb,....2.5 bar.
Regards Haans
Regards Haans
- V6 Capri
2.5Bar might be way too much for the carb.
2.5Bar = roughly 36Psi
Weber carbs need around 5-7 Psi which is aroung 0.5Bar.
So, it would just push it past the needle and seat straight into the engine.
Weber carbs need a pressure of no more then 2.3 PSI
Vw Solex will take 2.5 PSI
I think Nick meant PSI not bar.as that will blow any carb, but fuel injection.
- Camshaft
Correct Herman,..way too optimistic,....2.5 psi,.....sorry fot that.
Word from the ghuru is that Leon should have put a 32/36 carb on,.......we'll see what comes back ....will givefeedback.
Regards Haans
Regards Haans
have you tried adjusting the stroke of the pump jet arm?
- Camshaft
Fuel pump jet ,...a little squirt,............. fuel pours out from centre / secondary choke
Problem "disappeared" to Rowlands in Capetown. Awaiting feedback.
thanks for all input.
float not stopping the flow - or fuel pressure too high
Hi Nick, has the expert come back with your carb......
Whats the finding ...
or does he recommend a number plate conversion.....
Where you crane up the two number plates, and slide a new car in-between ....
- Camshaft
Jip,....carb is back jetted, but biggest change was made to manifold base. Getting things ready to assemble, but my friend has taken a turn for worse and is back in hospital,.....dehydration due to excessive vomitting. He's better though.
Will take a peek at the jetting as well .
Will share pics
Thank for asking Herman
Will share pics
Great news,.... the carb not your Friend...
Sad news ...... about your friend not the carb...
Hope she run right now, trust she will
- Camshaft
Ok , so I had the Phizer booster yesterday,...unfortunately I had to call in sick today,....really feeling kaaaky today.
top pic is the before,..... and the rest is the "after". positive our issues will be resolved.
one thing this gent said we must NOT do is to hook up the vacuum advance ????? according to him 36 DCD"s don"t like a Vac advance.
can"t get my mind around this one ???? your opinion ???
regards Haans
regards Haans
