1968 VW T2 Harness
andrewgdbn@gmail.com
What model do you have?: 1968
1968 VW T2 Harness
Post by andrewgdbn@gmail.com »
I am looking for some guidance on replacing or repairing a wiring harness on a 1968 VW T2 - it seems the previous owner did some damage when the indicator stalk stopped working and he fitted a toggle switch on the dash. Now the wipers are not working nor the toggle for the indicators. Not sure if the harness can be replaced or repaired? Many thanks.
Been thanked: 539 times
Re: 1968 VW T2 Harness
Best and easiest would be to fix the old Harness.
Getting a new Harness and fitting it is not that easy in the bus.
Go on to Google and get a wiring drawing for your model and sort out one wire at a time.
The indicator Stalk can be got from Volk Spares or Autostyle.
Good luck
Thanks Herman.
Camshaft
Been thanked: 107 times
Post by Haans »
Andrewg,...i know very little bout electrics,..but can gather upvery little common sense I might add,.....and a test lamp AND then you progress to a Multimeter '๐Ÿ•ถ ๐Ÿ‘€๐Ÿ‘€๐Ÿ˜๐Ÿ˜๐Ÿ˜™๐Ÿ˜‡ let me tell you ,..you'll even surprise yourselves !!
Forums such as this and others can be very helpful too.
Try it.
Regards Haans
