73type2
Posts: 1001 Joined: Fri Apr 21, 2017 11:37 am
Has thanked: 141 times
Been thanked: 100 times
Post
by 73type2 » Sat May 08, 2021 4:36 pm
I'm busy putting a Beetle 1200 engine back together and found sealing nuts used on the case. I would like to install new ones, but find that the closest nut in South Africa is nyloc. I read that the sealing nut has a rubber insert. Does anybody know where in South Africa I can get these sealing nuts, or can I just go ahead and use nyloc nuts?
Original nut:
slak
Posts: 1031 Joined: Wed Jul 14, 2010 11:07 am
Has thanked: 7 times
Been thanked: 32 times
Post
by slak » Sat May 08, 2021 10:05 pm
Seen them at Volkspares before but the last time i wanted they had no stock
but that was a while ago
U Only Live Once Right !!!
Posts: 15008 Joined: Wed Sep 14, 2005 8:33 am
Has thanked: 192 times
Been thanked: 488 times
Post
by Tony Z » Mon May 10, 2021 4:55 pm
you arent going to find them locally.
Use nylocs or standard nuts with copper washers
Posts: 4973 Joined: Wed Sep 14, 2005 9:24 am
Has thanked: 5 times
Been thanked: 98 times
Post
by calooker » Wed May 12, 2021 8:29 am
Use some RTV sealer at the base of the stud threads before bolting on the nut, does the same job.
Edmond
Posts: 1130 Joined: Sun Jun 15, 2008 7:57 pm
Has thanked: 22 times
Been thanked: 40 times
Post
by Edmond » Thu May 27, 2021 8:10 pm
Flat four racing used to seal these in a pack of 4 for the oil pump cover, they were not cheap something like R50 for 4
73type2
Post
by 73type2 » Fri May 28, 2021 1:01 pm
I use shellac gasket sealer (that molasses like stuff) at the base of the studs.
Edmond
Post
by Edmond » Fri May 28, 2021 8:15 pm
73type2 wrote: Fri May 28, 2021 1:01 pm
Thats my favourite sealant to use on beetle engines as well
