ID speedo’s
- Been thanked: 539 times
Re: ID speedo’s
Normally has a date stamp (month Year) on the back
Looks to be a Brasilia Bus speedo.
Or even a late Brasilia Beetle with alternative fuel use
Too big for Type 3 or KG
I Think
1979 Brazilian beetle
I Think
- Jdt1976
- What model do you have?: 1952 beetle
- Has thanked: 114 times
- Been thanked: 90 times
Re: ID speedo’s
I would say the light between 80 and 90 is when your headlights is om brights.
What is the date on the back if it got one?
- Has thanked: 193 times
- Been thanked: 121 times
Re: ID speedo’s
I am looking for two speedos. 1x 72 Beetle .
One speedo for Early bay in MPH not kph
- Riaan.N
- Oil Seal
- Has thanked: 3 times
- Been thanked: 37 times
Re: ID speedo’s
[quote="Terry Phillips"
[/quote]
One speedo for Early bay in MPH not kph[/quote]
Hi Terry, bus speedos I don’t collect….not on purpose anyway. ‘72 beetle…I’m not sure, the ones I have are all a bit different. Sorry
Will post more with time to get them ID’d.
[/quote]
- Chucker02
- Facebook: chattingh74@gmail.com
Re: ID speedo’s
Looks like a Thing speedo or an auto beetle. I have seen that ATF sign somewhere. Will have a look tomorow
- Jdt1976
Re: ID speedo’s
Seems like the ATF is for Automatic Transmission Fluid. I did see somwhere it is for the fluid level but in the pic it shows temperature.
Re: ID speedo’s
Here is a thread on that same speedo
https://www.thesamba.com/vw/forum/viewt ... sc&start=0
Copy of yours has the mark 4/77 so April 1977 and from Canada
