South African Gearbox Codes
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
I've done a search on this site for VWSA gearbox identification, but didn't get a definitive answer. I have the following numbers off two gearboxes:
Gearbox 1:
28
113 301 103
J
Gearbox 2:
16
113 301 103
Gearbox 2 comes out of my Beetle 1200 and has the short shafts, so I'm pretty sure it's a 1200 box. I'd like some help identifying gearbox 1.
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Re: South African Gearbox Codes
Post by Donovan D »
You should have some letters on there as well ??
-- viewtopic.php?p=223889#p223889
73type2
France
Post by 73type2 »
The only letter I see is J.
The number you looking for should be a stamped number as far as I know to correctly identify the box
Should start with SF
73type2
France
Post by 73type2 »
Before I go crawl under the car, where would you find this SF number on the gearbox?
If my memory serves me right, its above the filler plug,
But not too sure
73type2
France
Post by 73type2 »
Thanks, I'll have a look.
73type2
France
Post by 73type2 »
I crawled under the car and found the following code underneath the numbers previously shown:
AC 4288796 SF
According to online sources this gearbox is for 1500 and some 1300 from 8/70. Is this correct for South African gearboxes? If so, I have a 1600 single port that I want to put in this Beetle. Will it be fine?
73type2
France
Post by 73type2 »
