Hello all you buggists out there. I have been wanting to fit a rev counter to my buggy for a while. I was given one with the following connections on
the back. -12 -6 15 and then a plus sign. Can anyone tell me how to connect it.? would be appreciated.
Fitting a rev counter.
- Has thanked: 3 times
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Re: Fitting a rev counter.
Hi. Does it say VDO on the front face?
- buggyfan
- Long Block
- Been thanked: 541 times
If you running two wires to the back
you will place the 15 on the 15 or - (negative) of the coil. With the wire between coil and dissy
The + (positive) on the + of the coil
The -12 to the body (ground) of the car.
IF
You using a single wire to the back coil;-
You take the + to the ignition "ON" side of your ignition
The -12 to the body of the car
The 15 on the 15 or - (Negative) of the coil. With the wire between coil and dissy
Hope this helps
IF
Hope this helps
- Has thanked: 141 times
- Been thanked: 100 times
Herman,
15 is switched live, ie live with ignition on, so + side of the coil. 1 is for - side of coil, which is connected to the distributor.
We are talking here of his unit as per the connections on the back of the rev counter.
-12 is your ground ( not using -6 as this is a 12 volt car)
+ is your supply to the unit and to the coil from ignition key
15 is the trigger to receive impulses from the ignition points/ electronic unit to work out the RPM.
- Tom Bishop
- Single Port
- Been thanked: 5 times
Just to help out.
- 12 is Ground
+ is your Ignition Live (15) coming from the fuse box that would run to the 15 on the coil. You need to cut the wire after the fuse and connect it to this terminal.
15 is for the other side of the wire that you cut and continues to the coil.
IE. The Rev Counter receives its Pulse Signal by intercepting the 15 wire that runs to the coil.
- 12 is Ground
