CORRECT Electric Fuel Pump for Aircooled motors
Camshaft
Been thanked: 107 times
Re: CORRECT Electric Fuel Pump for Aircooled motors
Post by Haans »
Got it,....we are on the same page !!! Busy with layout in the rear in engine compartment ,....as low as possible.
Busy with CAD drawings,....already on rev2 !!!
Thanks to all. Haans
Camshaft
Post by Haans »
Cad rev2 .....and then the "proto type"
Just a sneak "preview".....still need to see how the wiring layout will be,....pre-fit,...in between all the other chores so gladly dished out bu missus😍😍😍😍
Regards Haans
Camshaft
Post by Haans »
Ok next episode!!!!.....after bols-up with primer on galvanise sheeting,.....strip all paint ,...repaint with galv primer.
In between all chores and all other household items,...
3 prefits and loosing bolts and a lot of inward swearing,....remaking the loom,.....I think I am ready to do the final fit,.......pretty soon!
Thank for interest. Haans
Whoow ! that looks great, nice job
Camshaft
Post by Haans »
Well,......now that the festive dust settled !,....it was time to fit this lot ,...rout the loom and !!,...fit the fuse and start!!
That's exactly what happened yesterday,.....Yes eventually
Impressed with the priming method! 2'nd swing and the old goat came out of it's slumber of about 3 weeks!!
Thank you to Dawie ; Herman; Tony and all of the others that assisted with advice and comments
Ps got video,...how do I load it ?,
Regards Haans
excellent job Nick, well done, looks factory.
BUT ........
The guys are going to tell you that you need to move the fuel filter to the other side of the fire wall.
If you now have a engine fire the filter will melt and the fuel will still keep coming.
Camshaft
Post by Haans »
Duly noted,......makes sense,....did'nt think aboutthat,....will replace fuel line and filter.
Nick
I see you are using the good fuel hose. Thats the same stuff I use - it'll last for years.
re the filter - you could consider a fuel injection filter - they do the same as the cheaper ones, but are made from metal to handle the pressure - so they wont hole through unless its a really bad fire. I wouldnt recommend this in a beetle to to where it sits, but in your situation, it is far enough away from the engine.
outside of the engine bay is still safer though
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
Tony Z wrote: Thu Jan 07, 2021 9:49 am I see you are using the good fuel hose. Thats the same stuff I use - it'll last for years.
Tony,
Please give more detail on the fuel hose. Who typically supplies it?
Camshaft
Post by Haans »
Tell you what,......by the time the filter melts,...and I have not noticed,......pls shoot on site!!😤😤
BUT,....I will change as soon as I can,...with new pipe,....filter has to accessable for an old fart !,,
Thanks again for all the advice
Its fuel hose rated at 20bar. I used to get it at Hyflo, but they are no longer
Most hydraulic places have Fuel hoses as well, as they are normally resistant to oil /fuel/ chemicals
You can select your pressure rating from the range.
Good Luck
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
Tony Z wrote: Fri Jan 08, 2021 6:46 pm Its fuel hose rated at 20bar. I used to get it at Hyflo, but they are no longer
Hyflo was taken over by the BMG group and they still stock all the same components as what the old Hyflo did.
BMG also took over the old Tool Quip and Allied company if you used to get anything there.
The only problem is you now need to know more than the BMG salesman as it’s become a big enterprise with staff that don’t know what they actually sell, stock or can do for you. Bunch of useless idiots.
Harry Jones
Post by Harry Jones »
Thank you for all that have contributed to this thread and all the other threads on the forum
about Electric fuel pumps this is why I really enjoy ACVWSA !
Been doing research on this topic for my engine build and want to go with an electric
fuel pump setup on a 1600TP type 1 motor with twin 36idf Webers, also going to be using
a G Tech electronic ignition system.
I spoke to the guys at Huco in Boksburg and was told the Huco 133010 has been discontinued
and the two options are the 443000 (Tank placement) and 443010 (Engine bay placement)
But reading here believe these are no good !
I see the other option is the Facet 40163 .... where can I get one of these ? Considering all
the drama at the moment don't want to try import anything and would prefer to walk into a
shop and get one ... ( not sure if this is wishful thinking )
Beside the above options are there any other options ....? what solution does Volkspares in Jet
Park offer ... ?
The guy in Boksburg is talking BS, he has said this for the last 6 years,
He only has the high pressure pumps in stock and nobody wants to buy them, so he refuses to import the right one.
The correct Facet is also hard to get, but you can go for a pressure regulator to bring it back to 2.5 PSI
Best you import the right one, ask @Haans he has just got one and these guys are professional suppliers, no sweat, you will have it in a week.
Or have Volkspares order the right thing for you, tell them what you want and they will get it.
Good luck
