Hi guys,
Where can I get ahold of a clutch and pressure plate for my 412. 1700. Complete kit would be great.
Sent from my SM-G975F using Tapatalk
Clutch for type 4 412?
Re: Clutch for type 4 412?
I stand under correction, but I think the 411/412 uses the same clutch as the beetle
- sean
- Has thanked: 63 times
- Been thanked: 227 times
There was an early 1700 flywheel that utilised a 200mm clutch (same size as a Beetle), but i'm pretty sure the splines differ on the Type 4's making the beetle clutch not compatible.
- Has thanked: 42 times
- Been thanked: 207 times
The 200mm clutch was used by early 69 411 cars.
Later cars used around 215mm size.
Pressure plate should be similar as 1700/ 1800 kombi but not 2L.
Clutch disc splines are 411/412 specific, so discs from a type 4 engined kombi will not fit.
So one would have to take the old disc and have it relined, where they re-use the inner splined section.
- mhsmuts
- What model do you have?: Variant type 4, 412
- Been thanked: 4 times
I measured the clutch and its diameter is 200mm, pointing to a beetle clutch? The vehicle was converted to manual somewhere in its life and received its gbox from a beetle then?
Are there stronger clutch options available in the 200mm?
- sean
No, although it’s also 200mm wide like a beetles, it is not the same as myself and Dawie have said above. The splines differ. Your only option is to recondition it.mhsmuts wrote: ↑Tue Oct 27, 2020 8:25 pm I measured the clutch and its diameter is 200mm, pointing to a beetle clutch? The vehicle was converted to manual somewhere in its life and received its gbox from a beetle then?
Although your vehicle may have been converted to a manual, it will certainly not have been to a beetle box. They are very different to what’s used in a type 4.
- mhsmuts
Thanks everybody, I'm doing the rounds this morning to find someone that can do it for me.
- mhsmuts
I found a company that can refurbish the clutch for me. Thanks for the advice
