lista544
Posts: 7 Joined: Thu Apr 02, 2020 10:47 am
What model do you have?: golf 5 gti 2007
Post
by lista544 » Thu Apr 02, 2020 10:51 am
Car smokes iv'e change the oil 5-30 to 5-40 bt still smokes wen i give acelaration bt not all the times mileg 193 plz help
Sent from my ANE-LX1 using Tapatalk
Posts: 15029 Joined: Sun Sep 18, 2005 5:54 pm
Has thanked: 231 times
Been thanked: 232 times
Post
by Pine » Thu Apr 02, 2020 10:53 am
Buy a Beetle
lista544
Post
by lista544 » Thu Apr 02, 2020 10:57 am
Done.. bought 3 of them
Vintage man
Posts: 279 Joined: Thu Apr 20, 2017 4:36 am
Has thanked: 51 times
Been thanked: 7 times
Post
by Vintage man » Thu Apr 02, 2020 3:28 pm
Are you using oil.
If you let it idle for a couple of minutes and then rev does it smoke,If yes valve stem seals.
Could be oil rings that have collapsed or worn.
Can you do a compression test.If compression is low then put a small amount of oil in the cylinders and repeat the compression test.If the compression picks up after you put oil in the cylinders then its rings.That will give you a guide as it does not necessary mean the oil rings but will indicate that rings are worn.
If it was a beetle then its ok as its old enough to smoke.
lista544
Post
by lista544 » Thu Apr 02, 2020 3:42 pm
Vintage tnx boet
Posts: 14952 Joined: Wed Sep 14, 2005 8:33 am
Has thanked: 180 times
Been thanked: 483 times
Post
by Tony Z » Thu Apr 02, 2020 10:58 pm
quite likely the turbo
engine is still newish
lista544
Post
by lista544 » Fri Apr 03, 2020 9:22 am
The car i took in bra i"ll let u knw wat happnd tnx alot again bra
Eugene
Posts: 1794 Joined: Mon Jan 22, 2007 9:30 am
Has thanked: 59 times
Been thanked: 65 times
Post
by Eugene » Fri Apr 03, 2020 1:58 pm
lista544 wrote: ↑ Thu Apr 02, 2020 10:51 am
Car smokes iv'e change the oil 5-30 to 5-40 bt still smokes wen i give acelaration bt not all the times mileg 193 plz help[IMG]https://uploads.tapatalk-
Please god....not another one
lista544
Post
by lista544 » Fri Apr 03, 2020 2:48 pm
Eugen wat u mean?
Post
by Tony Z » Fri Apr 03, 2020 5:02 pm
lista544 wrote: ↑ Fri Apr 03, 2020 2:48 pm
Eugen wat u mean?
he's just a miserable old fart
lista544
Post
by lista544 » Fri Apr 03, 2020 5:46 pm
Tony u were right brother (tarbo seal..) Prblm.. they can fix wat i have or buy a new one.. So again tnx alot buddy.
Post
by Tony Z » Fri Apr 03, 2020 7:25 pm
fix it, get OEM parts
buying new will likely get you a cheap part and it'll only blow again in a few thou km
lista544
Post
by lista544 » Fri Apr 03, 2020 7:28 pm
Salute
