carbs
butzi
carbs
Post by butzi »
hi Guys,
I need some advise on which is the best carbie to use on my 1.6 duel port buggy
solex 34 pict 3
or
solex brosal 30/31 pict
Thanks Butzi
Merlin
Has thanked: 20 times
Been thanked: 39 times
Re: carbs
Post by Merlin »
34PICT3
butzi
Re: carbs
Post by butzi »
Hi Merlin.
Thank you for your advice. I am very much a novice in this field and any other advice would be greatly appreciated.
Thanks.
Butzi
email ttheron6@gmail.com
acpaterson
Has thanked: 80 times
Been thanked: 131 times
Re: carbs
Post by acpaterson »
or if you can find then, 34 ICT's..
Been thanked: 98 times
Re: carbs
Post by calooker »
I have a complete set of 34 ICT weber carbs, bolt on kit. 082 830 6493
Vick
What model do you have?: 1970
Re: carbs
Post by Vick »
Could I "High-Jack this for a moment,
I have 1600cc single port and need the correct carb for it. Currently installed is the Solex 30 Pict 1 which I believe is totally wrong carb. Should at least be the Solex 30 PICT 3 as the pict 1 was for 1300cc??
What carb should I look at as replacement carb?
Trying to get the old 1970 bug going again for my son.
slak
Has thanked: 7 times
Been thanked: 32 times
Re: carbs
Post by slak »
Vick wrote: Sat May 30, 2020 11:40 am Could I "High-Jack this for a moment,
The newer replacement carb would be a 30/31 carb in what area are U
I might have a 30pict 2 i could swop for yours i will have a look just now and see what i have
PM Me your area
U Only Live Once Right !!!
