Assembly Lube
- Has thanked: 4 times
- Been thanked: 3 times
- Has thanked: 193 times
- Been thanked: 121 times
Re: Assembly Lube
my first few stock engines I built with engine oil, no issues there.
I've been using my own special concoction ever since, but that one is a secret
Re: Assembly Lube
Thanks Terry and Tony !!
Doing some reading and research I see the guys also use
Wynns Advanced engine treatment ... have either of you heard of this ?
https://www.wynns.co.za/product/advance ... treatment/
Re: Assembly Lube
No no no Wyns has Teflon in it and coats everything with a film and does not help the bedding in progress trust me on this its bad news for new engines. No additives and use a straight SAE 30/40 oil not multi grade to run it in. My opinion and experience.
Assembly use EP90
Assembly use EP90
