Go to one of the V8 shops and just get yourself a Proper pressure regulator they go for around R650
last i bought one and they are usually good quality and keep the pressure steady to werever
U set it
CARB......FUEL PUMP?
- slak
- Has thanked: 7 times
- Been thanked: 32 times
- slak
Re: CARB......FUEL PUMP?
I don't know Paris all that well but there is one in Alberton in South Africa
U Only Live Once Right !!!
- slak
important to fix that otherwise people will have sent U half way round the world
looking for parts
the guys there are very helpfull just tell them that U need one that can go down to 2psi
and they will know what to give U
what you need is the holley HO 12-80473type2 wrote: Wed Feb 27, 2019 11:08 am Sorry man. Not in Paris anymore. I'm now in Cape Town. I'll contact the shop in Alberton. Thanks.
this regulated between 1 and 4 psi, adjustable
if they dont have, then buy HO 12-803 and the rebuild kit which comes with springs for both the 12-804 and 12-803. Then swap springs, you now have the lower pressure one.
Try All American Parts in Milnerton or Motown in Stikland
All American is cheaper
- Has thanked: 141 times
- Been thanked: 100 times
I got the Holley HO 12-804 from Motown in Stikland for R800, plus a pressure gauge for R500. Thanks again for the tip Tony!
