T2 Head light conversion
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Re: T2 Head light conversion
Post by Terry Phillips »
I think you are the one needing a hand there Richard but hard work keeps you young.
didi
Been thanked: 37 times
Post by didi »
Terry Phillips wrote: Mon Jan 07, 2019 2:03 pm Thanks Didi how far in are the new brackets you fitted are they all the same depth to set the lights.
Hi Terry,
I used a template that was borrowed to me by Werner Alker. He made the template off a later beetle headlight that already had the tabs installed.
_______
Been thanked: 540 times
Terry my Early Bay is just about done in the spray shop,
Then a week at the upholstery, then back here for the assembly,
Will then take photos of the whole process to help you should you still want it.
Will give you both options, and give measurements for future guys wanting to do the same.
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
Herman, where is the project thread for this early bay you're talking about?
73type2
France
Post by 73type2 »
Sorry Herman. I just saw it under Projects.
Terry Phillips
Zambia
Thanks Herman the back is playing up so at this stage I cant sit for long so I will be in the horizontal position for a few days or week so no rush.
Thank you for your offer.
Terry Phillips
Zambia
Should there be a left and right light and backing plate as I seem to have both the same arrows on the side both face the same way. :?
Terry Phillips wrote: Sat Feb 02, 2019 5:45 pm Should there be a left and right light and backing plate as I seem to have both the same arrows on the side both face the same way. :?
The arrows are to show if RHD or LHD lights, so the arrows should face the same way....
unless they are being fired by Indians then too they will face the same way and not good to be in front of .. :shock:
:lol:
Sorry, could not help my self, but should be out my system now .. :roll:
Here are my Fleetline as well as my Beetle converted head lights to Golf 1 semi sealed fitted in place of the OEM reflector.
Terry Phillips
Zambia
Nice job there Herman looks good and neat. :flash:
