Dual Circuit Master Cylinder for Beetle
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
I've never had a Beetle's brakes fail on me but I'm considering changing my master cylinders to dual circuit, just for a bit of added safety. Are there any suppliers in South Africa? I'm in Cape Town.
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Re: Dual Circuit Master Cylinder for Beetle
Post by buggyfan »
A common mod is to install the mastercylinder from a golf mk1.
73type2
France
Post by 73type2 »
Thanks buggyfan. It looks like it just bolts on, with some re-orientation of steel lines, of course. I would also like to keep the reservoir in the stock position. Could this part be bought from Goldwagen?
buggyfan
Long Block
Post by buggyfan »
Yes, you'll be able to source a mastercylinder at Goldwagen. All you need to do is put a 30mm spacer between the Mc and the pan.
Will that master cylinder work with all round drum brakes?
We use them when we change to front disc brakes, but as I said, not sure about 4 drums.
buggyfan
Long Block
Post by buggyfan »
Dont know about that HR. Just a pic I got of Fb Aircooled hooligans page.
buggyfan
Long Block
Post by buggyfan »
Found this while digging through the archives
viewtopic.php?f=4&t=20089#p192946
Camshaft
Been thanked: 107 times
Post by Haans »
Ok ...this is also ontheto do list!!
Has anybody got a drawing /sketch of this spacer?,......can it just be aplain 30mm spacer ? OD and ID and precise length ?
Much appreciated
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
just a 30mm spacer, all you need is move the cylinder away from the "firewall" by 30mm
Camshaft
Post by Haans »
I take it then there will be tweaking of the brake rod to get the correct clearance of ? 5-10mm or less?
splitfan
Post by splitfan »
Haans wrote: Fri Nov 23, 2018 5:17 pm I take it then there will be tweaking of the brake rod to get the correct clearance of ? 5-10mm or less?
Correct :)
