the disc shouldnt move in relation to the caliper, so if it clears, that should be good enough. I'd say 1mm is fine, hopefully others can chime in.
The adapter will need to be trimmed down to clear. Easy on a lathe - your fathers lathe should work for this if he still has it.
- Been thanked: 541 times
Make sure you are using well fitting half thread bolts so that it can not move around in the hole.
Normally they supply you with a location bolt on the one side to stop the bracket from moving under braking.
If not, you can make a threaded tube and take up the clearance space around the bolt.
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Progess has been slow, but its coming along nicely.
Very nice work, keep it up
Now that its summer again, the garage is a better place to bee....
really looks good
- Has thanked: 193 times
- Been thanked: 121 times
All the pieces bits and pieces when it comes together you will be one proud man keep it up.
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
cool
- Donovan D
Some before pics.
These pictures were actually taken in 2015, the updated pics above was taken a year ago.
Progress has been very slow, but Im really happy with the work done.
- What model do you have?: 1978 Beetle
- Been thanked: 5 times
Great work on the bodywork!
Although I'm not one to comment on speed of projects, at least progress continues to occur... And once it's done and looks amazing, then hardly anyone (including yourself) will even pay attention to that anyway.
- Donovan D
A lot of work has gone into the body so far and its looking good.
Looks good, you can be proud.
What a differences a few hundred hours make....
- Jdt1976
- What model do you have?: 1952 beetle
- Has thanked: 116 times
- Been thanked: 90 times
Good progress.
Are you going to replace the “J-Strips” that takes the rubber that seals the bonnet and bootlet?
- Donovan D
I wasnt to fussed about it but now Im thinking I should try and get them on.Jdt1976 wrote: Tue Dec 04, 2018 12:42 pm Good progress.
Are there any local places that sell these strips ?
- Jdt1976
Not sure if someone local got them.
I get them from Virtanen.
https://restorationpanels.com/product/j ... and-hoods/
You just take the primer off at the places you going to weld so now after primer is the right time to do it.
