back fire on accelration
Vintage man
Has thanked: 51 times
Been thanked: 7 times
Post by Vintage man »
Hi all
Where to start ,1600 TP motor in a late bay.
When accelerating jerks and power low then it back fires.It started doing this and then cleared but this weekend no luck.Checked the timing and dwell angle and that is spot on.
John Alves
Has thanked: 3 times
Been thanked: 48 times
Re: back fire on accelration
Post by John Alves »
when does this happen? engine cold? engine hot? all the time? does it happen on deceleration as well?
touch the exhausts see which one is cooler than the rest, possible bad plug??
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
Vintage man
All the time ,seems only on acceleration .will check plugs and leads as soon as I get a chance.Will check the exhausts as well.Thanks
Eugene
Has thanked: 59 times
Been thanked: 65 times
Post by Eugene »
No...let John come feel the damn exhausts :twisted:
sounds like the pump jet isnt working as it should
Vintage man
Hi Tony ,I will check the pump jet system but it also does it a constant acceleration.Nothing on de-acceleration.
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
I had a similar issue on my '71 Beetle. I found a leak on the intake manifold.
Vintage man wrote: Tue May 29, 2018 11:38 am Hi Tony ,I will check the pump jet system but it also does it a constant acceleration.Nothing on de-acceleration.
Then likely a vacuum leak
John Alves
Eugene wrote: Tue May 29, 2018 9:22 am No...let John come feel the damn exhausts :twisted:
I now have a laser temp gauge so no more finger burns :)
1968 1500 SP Beetle
Vintage man
ok so what temp should it read
John Alves
the colder one would be the one with the misfire (if the problem is plug related)
1968 1500 SP Beetle
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Sucking air use the old hair spray trick, my 2c.
I think I was barking up the wrong tree.I was thinking of de acceleration. :oops:
Last edited by Terry Phillips on Sun Jun 10, 2018 11:03 pm, edited 1 time in total.
Vintage man
Reset the volume and bypass on the carb as per Google and runs smooths. Out on the highway and a bit of town driving, I'm chuffed, Thanks all that gave advice as I did do as adviced as well so another learning my bus.
