Think maybe you have an earth problem on your engine.
It looks as if when your voltage regulator kicks out from full charge, you get a spice to the temp gauge.
Put a heavy earth from your battery to the engine and try again.
Also look at all your connections.
VDO Oil Temp Gauge
- Been thanked: 539 times
Re: VDO Oil Temp Gauge
- Has thanked: 11 times
- Been thanked: 7 times
Gauge and sender not calibrated.
Remember VDO works the wrong way round ie if you earth the sender it reads zero on the gauge and open circuit shows full deflection
Doesnt sound like either to me.
From memory - VDO uses two distinct resistance ranges for their gauges and senders. I'll put money on the fact that you have incompatable parts and the 60deg that you are reading isnt actually 60deg and when the gauge goes out of range, you are in fact going out of the gauges operational resistance range.
- No More Landy
- Has thanked: 23 times
- Been thanked: 6 times
No. The sender and gauge worked many years together. When the gauge goes wrong it is very sudden jump to full. Will try a direct earth to the sender body as suggested
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
- No More Landy
And the winner is.................Herman
Cleaned my earth strap between body and gearbox with wire wheel and the associated studs, washers and nuts making contact, and abra cadabra, gauge sorted.
Who would have thought of such a gremlin.
Thanks Herman - great faultfinding/experience.
1971 Beetle
2021 Polo tsi
2021 Polo tsi
You more then welcome, you on you way, that's all that matters.
Enjoy
Enjoy
- Oil Leak
- What model do you have?: Not yet
- Been thanked: 2 times
Subaru sells a bung to the same dimensions as the relief valve screw. It has 1/8 npt hole for sensor
