My Daughters ride
FaanP
What model do you have?: 1971 beetle
Re: My Daughters ride
Post by FaanP »
I would first put the wheels on and then take a look again. But as is I would go down more in front. Back can drop a little as well. That's just my preference
Been thanked: 487 times
that looks just perfect. Not too low, but nice and low.
You'll still have to look out for pavements when parking though
mcg
What model do you have?: 69 vw beetle
Post by mcg »
i think lower in front by at least 200mm
just wish it was my ride :D
maybe the next one :P
mcg
Post by mcg »
ok if i look at the stance of the bug
the front wheels are protruding further out of the
front due to the disc brake conversion maybe i
should do the back as well what you guys think
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Dont they put spacers on the back I think there are spacers you can buy not sure who has them but try local gumtree.
mcg
Post by mcg »
Ok Terry so what you saying is just put the spacers on the drums
to take the wheels out that 100 or so
Terry Phillips
Zambia
I have never done a conversion so I am just throwing ideas around I know there are spacers but I could not tell you the sizes and what you would need but I am sure you will get a reply from someone who knows the procedure and can give you the advice you need.
Google Volkswagen Beetle Wheel Spacers you will get what you want there.
Last edited by Terry Phillips on Tue Jul 04, 2017 9:10 pm, edited 1 time in total.
mcg
Post by mcg »
someone please
looking at your pics, it looks more to me like your front wheels might interfere with the fenders and that the rears are in the proper place.
Spacers arent difficult to make up. Send me a drawing of what you want and I can make them for you - otherwise go to a local machine shop and have them make up a set.
mcg
Post by mcg »
Thanks tony but i want the front and back to look the same will cross that bridge when i get there
mcg
Post by mcg »
maybe go a 205/65 15 on the rear
and a 175/65 15 on the front as tyres i got are 186/65 15
FaanP
Post by FaanP »
The tyres could help.
100mm spacers a bit of stretch imho
Piet
What model do you have?: type 3, Porsche 550
Been thanked: 15 times
Post by Piet »
FaanP wrote:The tyres could help.
I have a question for the people that know morr than I do: I assume that if the wheels at the back are 100mm out of line with the front wheels that means the front wheels are 100mm offset from where they were. So will your steering geometry not be badly messed up? The way I understand it is that if you draw a line through the kingpin it should end exactly in the middle of the tire where it hits the road?
FaanP
Post by FaanP »
If the line through the kingpin goes through the middle of your contact patch it means you have 0 scrub radius. When you move your front wheels out by adding spacers you increase the scrub radius.
A positive scrub radius will increase steering effort and road 'feel' increases, as the steering is more susceptible to road shock.
mcg
Post by mcg »
And we have light
