fuel No LRP
fuel No LRP
I actually just found no lrp petrol available
I have 1600 vw beetle
What are my options
Please help
What are my options
Please help
Re: fuel No LRP
use unleaded
the vw engine was made to run unleaded unless it was butchered by some monkey during a rebuild.
- Kafer74
- Oil Cooler
- What model do you have?: Beetles
- Has thanked: 37 times
- Been thanked: 13 times
Re: fuel No LRP
Hi
Where do you stay? There is an additive from WYNNS that you can buy at most fuel stations. You can also buy Valve Ease.
Hennie
Hennie
Enjoy the Ride
1970 Westie called Ben
- freddiebooysen
- Been thanked: 47 times
Re: fuel No LRP
What is that additive called?
You guys recon unleaded will be ok no big damage to the engine wear en tear etc ?
What does the additive do ?
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: fuel No LRP
Stop worrying about additives and what fuel you use, just throw in petrol and drive. Nothing to worry about.
- Muderick
- Has thanked: 42 times
- Been thanked: 69 times
Re: fuel No LRP
Like Tony and Sean said, just use Unleaded.
I have been using unleaded for 4 years and just pulled the motor this weekend. No damage anywhere to the valves, seats nor pistons.
Muds
Muds
- These users thanked the author Muderick for the post:
- splitbusahollic
![Image](http://www.animated-gifs.eu/transportation-cars-beetle/0002.gif)
Old School or Bust!
- freddiebooysen
Re: fuel No LRP
When I bought my '72 1600 Beetle, the previous owner warned me to only use LRP. After extensive searching on the 'net, I realised that it was a load of bollocks and that unleaded is perfectly fine. And it has been. Not one problem and it goes better on unleaded.
- Rowan
- What model do you have?: 1967 Beetle
- Been thanked: 5 times
Re: fuel No LRP
Would unleaded be suitable for all beetle engines? Even a 1500 on a 67 Model?
" Don't gain the world and lose your soul...Wisdom is better than silver or gold " - Bob Marley
- Been thanked: 540 times
Re: fuel No LRP
As far as I know, all vw aircooled engines, have hard insert valve seats, so yes, they can run on Unleaded.Rowan wrote:Would unleaded be suitable for all beetle engines? Even a 1500 on a 67 Model?
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 321 times
Re: fuel No LRP
I would double check that. I don't know when VW heads were made unleaded safe, but I suspect it was only in the early to mid-1970s, ie, twin-port engine era.retrovan wrote:As far as I know, all vw aircooled engines, have hard insert valve seats, so yes, they can run on Unleaded.Rowan wrote:Would unleaded be suitable for all beetle engines? Even a 1500 on a 67 Model?
I know that very early engines of the split and oval era were not made for unleaded (it didn't exist back then). From my interactions with vintage VW collectors in Germany, they run unleaded and add a lead additive to every third tank of fuel.
Re: fuel No LRP
You may be right, but I am basing my statement on the fact that we do not use hi-octane in South Africa.
Here is a verifying statement from vw-resource.com
In his "Compleat Idiot" book John Muir admonishes us strongly to NEVER use unleaded fuel in a VW engine. Of course now we can't buy anything BUT unleaded fuel in the U.S. Volkswagen has stated that all of their heads from about 1966 on have been made with hardened valves, seats, and valve guides. For this reason the aircooled VW engine does not need lead (or lead replacement) to protect the engine from Valve Seat Recession (VSR) and so the octane number is the only consideration. If your heads have been rebuilt, then the machinist probably used the good silicon-bronze or aluminum-bronze valve guides. Also, the valves need no rubber valves seals (as they point spring-end-slightly-down to drain excess oil off), and so get plenty of splash oil on the spring end, which is enough for the valve guides.
Unleaded fuel should be just fine for the VW engine. The octane number of unleaded IS sufficient, provided you are using the "standard" VW compression.
Other makes are known to have a problem, have not heard of any vw aircooleds with problems.
Maybe guys like Arno, or Impi or Jurgens, can tell us of motors that have died because of unleaded.
- Cyberbeast
- Oil Cooler
- What model do you have?: 1974 Beetle
- Has thanked: 13 times
Re: fuel No LRP
I use unleaded or LRP... depending on what I can find. I cannot really notice a difference between the two. My Beetle runs the same on both.
For guys in Pretoria, Moot area, the Shell on Nico Smith street & 33rd Avenue still has LRP...
© CB ©
- Kafer74
- Oil Cooler
Re: fuel No LRP
Maybe we strat a thread indicating where LRP petrol is still available.
The Total garage in Pierre van Rhynefield, Pretoria
- These users thanked the author Kafer74 for the post:
- Cyberbeast
Enjoy the Ride
Re: fuel No LRP
Go ahead, start the threadKafer74 wrote:Maybe we strat a thread indicating where LRP petrol is still available.
