1973 VW Kombi with 2L CJ
Ryanggj
What model do you have?: 1973 kombi 2L CJ
Post by Ryanggj »
Hi all
First post! So brief intro: owned a beach buggy before, huge learning curve, loved every second.
So bought a VW Kombi yesterday. It's a 1973 baywindow Kombi. Motor was probably changed as its a 2L CJ. It also has dual solex carbs.
Got her running today and went for a drive- running on 3 cylinders and have a big oil leak :( i know what I want to fix and will post on the tech forum.
I am based in Northcliff, JHB. Anyone near by who knows the motor. I have to admit there I for on the web on this motor is very limited.
Enjoy the pics ;)
Been thanked: 487 times
Re: 1973 VW Kombi with 2L CJ
nice bus. Looks like its been stationary for a while?
Try change your spark plugs and check for vacuum leaks before worrying too much about what might be wrong.
Ryanggj
Post by Ryanggj »
I Will give it a good service this coming weekend As It has been parked for a couple months. However I know the distributor needs to be changed The cap doesn't fit the base. I have posted in the advise tab- if like to put in a electronic ignition, but battling to find any info on the CJ motor
Congrats on your new bus 8)
Jdt1976
Has thanked: 114 times
Been thanked: 90 times
Post by Jdt1976 »
Bruce in Discovery is good with aircooled engines. He done my CJ motor. 0117631500.
64 Notchback
Has thanked: 78 times
Been thanked: 37 times
Post by 64 Notchback »
Apologies for the Hijack
What is the difference between a CU motor and a CJ motor?
I was under the impression that the CU was a 2L and CJ a 1.8. I have a Cu in my DC and it is giving me uphill as one of the Hydraulic Lifters keeps on "Running Down".
So I am cosidering swopping the motors.
And congrats on the bus
Has thanked: 42 times
Been thanked: 207 times
Post by Dawie »
Looks like a nice kombi, congratulations. First i would confirm that the spark plug gaps are no more than .6 to .7mm maximum. Or replace plugs like Tony mentioned.
"CJ engine" = 2L solid lifter
"CU engine" = 2L hydraulic lifter, from later shape kombi.
64 Notchback
"CU engine" = 2L hydraulic lifter, from later shape kombi.[/quote]
Thanks Dawie.
Ryanggj
Post by Ryanggj »
She just needed a good clean.
that does look pretty good, nice
headworks#1
What model do you have?: 2275cc B BUGGY
Been thanked: 7 times
Post by headworks#1 »
Congrats ,
Hope you are Joining us for the Kaapse Kombi Kult near Parys ( Lochvaal)
Magoo1975
What model do you have?: 1968 Single Cab
Has thanked: 2 times
Mexico
Post by Magoo1975 »
Wow, what a good find!
Enjoy!
