Rebuilding a 718 RSK
Porsche and replica Porsche posts over here.
64 Notchback
Has thanked: 78 times
Been thanked: 37 times
Re: Rebuilding a 718 RSK
Post by 64 Notchback »
Thanks Shaun
I had basically the same idea of securing the clam shell as you have got only I will be using two pins and a different frame setup
Thanks for the pics
shaunnadan
What model do you have?: 68
Post by shaunnadan »
I've got a pin on either side.
So it's 3 hinges (left , middle and right)
2 pins on the frame
A piston in the Centre
And a latch on either side .
JonnieOC
What model do you have?: 718 RSK Replica
Post by JonnieOC »
That is a very nice idea for the clamshell, thanks for giving me ideas when I start doing mine
There was a time Albert Einstein couldn't count to 10 either
I drive a beetle which had severe plastic surgery
