IMPI - Bearing sizes ?
Has thanked: 36 times
Been thanked: 50 times
Post by flatfourfan »
Armand, I tried calling you this morning, but to no avail.
My wife shoved my wallet through the washing machine and with it, my list of bearings for the type 4. Can you remember what sizes we discussed as I'm going to be placing an order from the type IV store. While I'm ordering from there, is there anything else that I need engine wise?
They work about R600-00 for a set of german ones and about R350-R400 for brazillian ones.
I'm going to be coming through at the end of the month and I have some stuff to add to the collection of goods at your place. We'll have this turbo motor built in no time... :wink: ..
Is that how much bearings go for?!
Damn!!
I'm going to have to buy the same bearings also :?
Anyway, that engine sure sounds exciting, even though I had to copy and paste your text in MS Word to read it :D
Keep us posted!!
I'm going to try a few local places this week as well....
flatfourfan wrote:I'm going to try a few local places this week as well....
I'm looking for 0.50 (N0 2) undersize bearings for the crank and rod bearings
Let me know if the local places have...
Will do, last I heard I was looking at about R250-00 a set locally, but no-one has any in stock.
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Hi
Mains All for std casings (aint type four guys lucky?)
std crank
0.25 crank
0.5 crank
0.75 crank Sinter metal and metal leve are very good brazil bearings
STAY AWAY FROM SILVERLINE I wouldnt worry too much about German bearings.
2liter crank big ends
std , 0.25 0.5 . and 0.75 This is for 50mm journal
1.7 and 1.8 big ends (55 mm journal)
Dont forget cam bearings and those 96mm pistons
Okay, I've just got an email back and the bearing sets that you asked me to go for are about R10 000 excluding the pistons...........
eish..........
Any chance you can start stripping and measuring up so that I can order specfic sizes?
Ps, I have a lead on a set of 96mm 2.0 pistons and sleeves from Mahle for R2000-00 (good buy???)
Been thanked: 98 times
Portugal
Post by calooker »
Good luck finding T4 main bearing local, very scarce at the moment.
I'm buying my bearing sets from Jake Raby.
I got 2L 60" 96mm with ceramic coating
R1850
Portugal
Post by calooker »
type 4
021198493A, 20 case, 10 crank $37.00
021198495A, 20 case, 20 crank $37.00
021198497A, 20 case, 30 crank $37.00
This is what I get from the US if you need oversise or standard they vary a couple of $'s
calooker wrote:type 4
I need standard case and .50 crank, can you get those?
Bugger wrote:I got 2L 60" 96mm with ceramic coating
R1850
Pierre, I've spoken to Armand and when he drops off your motor, he'll have a look see at them and advise me on what to do.
- G
If He looks at it and says its" OK" for new then the price is double
Heheheheheheheehehehehehehehehehe :D :D :D :D :D
