'74 Devon Bay Camper - Winston
acpaterson
Has thanked: 80 times
Been thanked: 131 times
Re: '74 Bay Camper - WINSTON after surgery.
Post by acpaterson »
M,
I'll only be able to check when I next go to the panel Shop. I know they are an industrial type tyre and were quite expensive according to the P Owner. I know for sure they are a taller profile than 65's.
Lols at my "Passion gap".. haa haaa haaa... :hangloose:
Bossie2004 wrote:Alan, the last photo makes Winston a properse Cape bus...looks like a "Passion Gap" there bru... :D :D
You mentioned
acpaterson wrote:... I got the needle up to 110 kms.. Bus sounds ok, feels ok, I'm not foot flat, and all seems good. I'm going to do a speed test with an App on my Blackberry when I get him back, see exactly how accurate the speed is because I've got slightly larger dia tyres on the bus....
what size are the tires on Winston then, I've been told that I should look for 185/65/14's - read that the Hankook RA08 is the preferred replacement for the Bay's, else Kumho or Vredesteins - all contracted by VW to design tires for the Kombis...I have to replace mine for Roadworthy.
I've also downloaded an APP on my phone (NavierHUD - Heads Up Display) that I'm testing - gives you lekka directions and speed/time/etc on the windscreen - just need to find a way to see it properly at daytime - seems they use some kind of a transparent sheet stuck on the windscreen to assist with the daytime display...
Cheers,
Marius.
Looks like you read the thread I posted or got it directly from their site... http://www.busdepot.com/details/tires/
For what its worth, you can buy 8 ply tyres locally.
TWT might carry the Hankook RA08. They tried to sell me Hankooks before...
Otherwise, I got a reply from autoquip - 195R14C firestone cv2000 8PR @R950.00 each
Bossie2004
What model do you have?: '74 Volla
Been thanked: 13 times
Post by Bossie2004 »
Tony, Indeed, I've worked through BOTH last week to make sure I get the right shoes on the bus- not wanting gravity/g-force to change the shape of SKYE. I'll ask about the 8ply when I replace the rubber.
- Marius V
Speedster Replica
Has thanked: 45 times
Been thanked: 208 times
Post by Dawie »
Baywindow standard tyre size is 185R14C. Which is around 185/83/14 or 185/85/14. Using 195R14C should be fine, that was the size for the first aircooled third generation kombis-(80 onwards).
acpaterson
So I went to check the tyre sizes, as well as the progress.
As I mentioned, mine sits slightly higher than the normal busses, which I do like. The reason, I have 195 R14C tyres.
I like my new air-conditioning..
Branden's also performing miracles and has made me some stunning sliding window surrounds. Will help to finish off the interior once I start making panels up. :drunks:
Lots of work to be done when I get him home, but I think the finished result, de-rust, removal, straightening out and prepping, respraying, is going to be awesome when completed. ETA is 31 March.
:hangloose:
Derek
What model do you have?: 1971, 1972, 1978
Facebook: Derek Antonio Serra
Been thanked: 25 times
Post by Derek »
The 185 R 14 tyres are readily available, priced from R 750 for Roadstone's at Good Hope Tyres to around R 950 for Dunlops.
The camper is beginning to take shape Allan - it's going to look stunning in red and white :)
'70 Dormobile - 1.6
'76 Brasilia - 1.6
acpaterson
3 Months later, we FINALLY get some paint..
Starting to get somewhere finally. And LOVING the flat and straight reflection in the side panels. Straight as they should be. :hangloose:
Few more days hopefully.
Brandenmance
Post by Brandenmance »
Wow that.s looking good all! Can.t wait to see it all come together!
Very nice to see the bus with some colour.
Looks as if you too like RED.......... :roll:
keep the pic's coming.
Cyndi Kritzinger
Facebook: yes
Been thanked: 64 times
Post by Cyndi Kritzinger »
HI AL.
WHAT ARE YOU USING FOR WINDOW RUBBERS?
BEEN BUSY WITH A FEW BUSSES RECENTLY AND FOUND THAT THE LOCAL STUFF DOESN'T FIT WELL ESPECIALLY FOR THE SIDE WINDOWS.
COMING ON NICELY. ALWAYS EXCITING WHEN SOME COLOUR GOES ON.
MARK
acpaterson
Hi Mark,
I have a full set of Rubbers from the UK that will be going in, courtesy of Mr Branden Mance. I think Muds brought them in originally.
regards
ALan
acpaterson
He's looking SPLENDID in his new clothing...
Possibly am bringing him home this weekend, and then the interior starts. :hangloose:
Coca Cola bus!!
Looking good. You seem to have good luck with your panel beaters judging by how the speedster came out and progress on the Bay 8)
Muderick
Has thanked: 42 times
Been thanked: 69 times
Post by Muderick »
Cyndi Kritzinger wrote:HI AL.
MARK
Hi Mark, Like Alan says those full 36 piece rubber kits from Custom and Commercial are the real McCoy... better than German OG quality and fit like a glove.
At almost 400 GBP, its tough swallowing a bitter pill of R8000 just on rubbers, but are worth it in the end as they stop a lot of water getting into those nooks and crannies and later costing you another visit to the panel shop.
Hes looking sweet Alan.... you have 2 weeks to finish it and join us on our West Coast camp over on 30 May 2015 :twisted:
Muds
Old School or Bust!
