This is going to sound funny, but someone warned me a few years ago about that same crap when i was busy doing disc brake setup on my beetle, and they especially warned me about that calipers from Goldwagen. Nothing against GW.jmvv wrote:Got to Petrus on Monday and had no brakes. Only an ominous puddle on the inside of the right rear wheel. Checked the calipers (four wheel discs) and noticed the brake fluid running out next to the parking brake pivot.
Seems the caliper developed a leak between the fluid chamber and the parking brake pivot (Thanks Goldwagen) The calipers were fitted about two years ago and normally invoices don't hang around that long.
Long story short....R1300 Randelas later I had a new caliper fitted. Hope he sticks to his house training regime now with no more puddles...
- Gerlach
- Oil Cooler
- What model do you have?: 1976 Type 1 beetle
- Has thanked: 9 times
- Been thanked: 4 times
- Gerlach
- Oil Cooler
I Drop the stuff off past Tuesday, so just waiting for the callGerlach wrote:Today was just to crazy at work, so i need to take it next week. All wrap up and ready to go.
- JMartinVW
- What model do you have?: Between projects
- Been thanked: 11 times
I very nearly conceded defeat and joined the 'hate-of-anything-weber-36-dcd-carb' club, but since I could not leave my rat not running (call it mechanical sympathy, OCD or whatever), I had to figure out what was wrong. Eratic idling, miss fire and smoke belching, a real doomsday car. Anyway, I sheepishly put the stock solex carb back and sure as nuts, the boost diaphram tore real nice, so I replaced that with one laying around. Fired it up after plenty trouble, and figured that the faakin weber had burnt the inlet valves. So next step was to check and adjust valves, but even doing so, the engin still didn't want to run right. Had to get the revs way up before it fired on all four. Plugs checked, carb cleaned out everywhere, and then it dawned on me to check the dizzy. Here's the lesson to all - if it's not firing on all four, check the bloody points first! The points didn't open at all, but only started to open a bit once the dizzy would advance, hence the high revs needed to make it 'run'. Felt like a real tosser. Oh yes, and I got the rat licenced and transfered onto my name. Real productive day afterall. Sorry for the 'essay', but had to share my findings. Ps: I putting the weber back on, so no new club to join for me. Cheers.
'What? We can't stop here...this is bat country!' - Raoul Duke
- What model do you have?: Porsce Spyder
- Has thanked: 3 times
- Been thanked: 7 times
Don't worry we have all done similar things. I've learnt the hard way to allways check the basics first.
- JMartinVW
Thanks for the encouraging words Mars67. So glad I'm not alone. Just reread my original post, and it seems like poor spelling got the best of me that time of the night
I did put the weber carb back on, and the little beast is going like crazy baby shite again! I feel like the first I was allowed to drive - any excuse to drive, even if it's just around the block. My two year old decided that the dicky seat is her spot, so I always have an enthusiast onboard
- 62vwbeetle
- Oil Seal
- Has thanked: 6 times
- Been thanked: 12 times
First saturdAy with a splitscreen so new battery and earth strap installed. Changed fAnbelt fitted chrome trim rings to back lights. Drive her around and smiled a lot
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Thanks to Gerlach's helpfullness, I managed to rebuild a shot Alternator, and get it fitted and the car PURRING in time for this weekend's Bug Jam..
- Has thanked: 18 times
- Been thanked: 58 times
MOOI62vwbeetle wrote:First saturdAy with a splitscreen so new battery and earth strap installed. Changed fAnbelt fitted chrome trim rings to back lights. Drive her around and smiled a lot
- 62vwbeetle
- Oil Seal
Longest small job ever fitted door striker repair kits to my Ghia 3 months for parts 20 min to fit. Now car is drivable without its suicide doors hehehhe
- John Alves
- Been thanked: 48 times
fitted short shifter conversion kit (bought from FFR at Bug Jam) to my buggy, worked 100% first time.
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
- Wentzel
- Been thanked: 13 times
Gave my Beetle a wash before it rains again and took a spin to test the boost I turned up a bit. Feels good!
Oxyboxer Project
- Gerlach
- Oil Cooler
Wentzel, what setup are you running on your turbo motor?Wentzel wrote:Gave my Beetle a wash before it rains again and took a spin to test the boost I turned up a bit. Feels good!
- Gerlach
- Oil Cooler
Got my stuff back from flat four racing today for 92mm fly cut. Starting to look like something know.
Gerlach
I think its about time you open your own project thread....
- Gerlach
- Oil Cooler
hahahahahaha!! But then i'm not going to do my work at work.Tony Z wrote:Gerlach
