Ratrod build
JMartinVW
What model do you have?: Between projects
Ratrod build
Post by JMartinVW »
Hi guys, I know this is not everyone's idea of a 'great' bug. This is just to show that a lot of work, blood, tears and smiles went into this thing. Hope you enjoy.
I started off with this '74. Not in bad shape, nut PO pranged it on right front - really just cosmetic damage. And a bit of rust here and there... :oops:
Removed rear fenders and bumper. Also cut away the apron.
Nice and shiny! Bit of a dress up of the old motor.
I had these 1" wheel spacers made. Kept it on rear wheel, but took the front spacers off due to being unstable. They weigh approx. 5-7KG each.
Blimp indicators on the bonnet.
Twisted conrods for head-light mountings. Try to convince your local engineer that this is the best configuration for a conrod to go back into a motor, and check his facial expression! :lol:
8" beam extender, with longer brake lines. UJ steering shaft lengthened about 8".
Finally some paint goes on. These two guys really got the hang of the matt black after a few tries, and finished the entire job over a weekend. :hangloose:
Final verdict: Think twice before attempting to transform a bug into a ratrod / volksrod. It's an extreme case of money-into-a-bottomless-pit scenario.
If however you do decide on it, PM for any parts needed and/or ideas.
'What? We can't stop here...this is bat country!' - Raoul Duke
MrT
Has thanked: 22 times
Been thanked: 9 times
Re: Ratrod build
Post by MrT »
Thanks for sharing! Good to be able to see transformation!
