My Beach Buggy
headworks#1
What model do you have?: 2275cc B BUGGY
Been thanked: 7 times
My Beach Buggy
Post by headworks#1 »
riaanj
Been thanked: 41 times
Re: My Beach Buggy
Post by riaanj »
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
headworks#1
Re: My Beach Buggy
Type 1 Engine Specs: Case: Low Mileage Brazilian Type 1, tapped for full flow. Braided Stainless steel lines and aluminium racing fittings. Both sump and full-flow filters. Engine: blue-printed and balanced, 2180cc. Crank: Scat forged chrome-moly, 8 dowelled, 82mm stroker, counter-weighted. Straight-cut steel cam-gears. Rods: balanced, stock. Pistons/Barrels: Mahle 92mm Forged. Cam: Scat C-55, 312 deg duration, approx 12mm lift. Lightened Fly-Wheel, button clutch. Carburettion: Dual, dual barrel, Weber 48IDA 4R, matching manifolds. K&N Filters. Holley blue rotary fuel pump with regulator. Cylinder Heads: CB Performance 044 Magnum, 42mm inlet X 35.5mm outlet, stainless steel valves, high-rev springs, phosphorous bronze racing guides. CB Performance, Chrome-moly, solid ratio rocker arms, 1.25:1. Exhaust: CB Performance, merged, four into one drag-race header adapted for street use with silencer, (1 and 5 eighths of an inch diameter). Ignition: Crane Cams, Hi-7, electronic capacitive discharge ignition, Bosch 009 distributor, spiral core, stainless steel plug cables. New Forged Cr Molly H Beam conrods to be fitted soon to allow engine to rev safely to 7000Rpm
riaanj
Re: My Beach Buggy
Post by riaanj »
Awesome buggy dude, sweet specs. too.. :hangloose:
Honda CBR600RR
Honda CBR600F4
splitfan
Has thanked: 46 times
Been thanked: 26 times
Re: My Beach Buggy
Post by splitfan »
I like ! :)
Loopy
Has thanked: 11 times
Been thanked: 6 times
Re: My Beach Buggy
Post by Loopy »
Looking good! Any info/pics re chassis & interior?
Dazz
What model do you have?: T3 Syncro
Has thanked: 2 times
Been thanked: 4 times
Re: My Beach Buggy
Post by Dazz »
This thing must hall @SS. it must be fun at traffic circles in the wet. Especially the big ones like the waverley circle in PTA. it must be very tail happy in the wet.
Measure twice CUTonce.
1975 Kombie
1979 Kombie
W203 C320 CDI
'68 Austin Cambridge A60
Looking for a kombi project
headworks#1
Re: My Beach Buggy
Dazz wrote:This thing must hall @SS. it must be fun at traffic circles in the wet. Especially the big ones like the waverley circle in PTA. it must be very tail happy in the wet.
Believe me the tarmac dont need to be wet do drifting around corners or trafic circles will never try it in the rain only under controlled conditions such as Zwartkops might be there on 16 March.Will post pics of interior later this week
Wentzel
Been thanked: 13 times
Re: My Beach Buggy
Post by Wentzel »
Very nice and neat buggy. Engine must have cost you a bit. Did you go to Zwartkops? I wanted to but things didn't work out. Hope to see you at some events this year.
Regards
Wentzel
Oxyboxer Project
headworks#1
Re: My Beach Buggy
I decided to too fit H beam conrods to my existing motor due to the rev limiter only set at 5200Rpm to protect the standard conronds from breakage. The cam only starts working from +-4800RPm and is advertised for power up to 7000Rpm in order to utilise the big duration of cam this was best thing to do. After 10 months in surgery the motor is finally back. The postal service strike took a huge 4 months out of this engine rebuild period. Motor was send to Impi for strip down inspection and improved parts fitment. Forged Cr/moly H beam conrods fitted ,double valve springs fitted with Cr/Moly retainers, Shadeck 32mm oil pump, new Mahle bearings mains ,big ends and cam. A 1 5/8 merged header with stinger and a phat boy muffler for cruising also in the works. The Fan casing was heater ducts removed and a plate’s silver soldered into the openings to smooth the overall look and painted 2k Audi rocket red together with the remaining tin ware.
A Big thank you to Impi and Rudi with the help with this rebuild. :hangloose:
Will try to load Photos this weekend from home.
